Question about Canon PowerShot S30 Digital Camera
LCD Dispaly malfunction
I have a Canon S30 digital camera, 5-6 years and it worked perfectly until last week.
When I turn it on, the lens comes out normally but there is no image on the LCD screen. The shutter works but it does not take a picture. I can't get the menu to come onto the screen either.
Whats wrong?
gil
  • mrgil Dec 05, 2007
    I checked the memory card and there are pictures recorded..So this means the Camera is working but there is no image on the LCD screen.
    Does this mean its the screen???
  • jopa Dec 09, 2007
    Encountered almost same problem yesterday, S30 is 6 years old. LCD screen is now all-white (backlight seems OK).
    Problem Solver:
  • 17 Answers
The screen has two components. The LCD, and the backlight. You can buy broken cameras relatively cheaply on ebay (or if you have it, craigslist). Do that, and you might be able to replace the screen.
Posted on Dec 09, 2007
I have a Fuji finepix j38 that is appox. 8 months old. When I turn the camera on, the lens comes out, immediately retracts, and "zoom error" comes up on the LCD. I can view pictures, but can't take any. ...
I thimk your problem is that you have sand betwin the lens mechanism and that cause the immediately retract.you can try to apply air pressure near the lens but with care
Oct 05, 2010 | Fuji Cameras
Hello, I love my sd600 had it 4-5 years.... last week it started making a noise when the lens is extending or retracting....it still works fine but I am puzzled by the noise... is camera on its last leg....
Hello Dave.
The sound which you are hearing is the the lens motor. When you can start hearing an unusual noise hear, i would suggest that you take your camera in to your nearest repair shop, before any further damage is done.
The next step will be a lens error.
Hope this can be of help.
Kind regards
Andrea
Sep 17, 2010 | Canon PowerShot SD600 Digital Camera
Canon power shot sx100is LENS ERROR
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens makes noise when camera is turned on/off
I had the same problem and took it back to where I purchased it (5 months previous) and had it sent away for repair. I was asked if there was any sand in the lens or if I dropped it (no to both) Turned out that the lens had to be replaced due to malfunction.
Sep 24, 2009 | Canon PowerShot A480 Digital Camera
Lens stuck out, camera won't switch on, Canon G9
I have fixed my g9 twice with the lens problem. 1st time I dropped the camera on asphalt lens closed. Turned on, lens stuck and not forcusing or retracting. Solution was to press lens against a door frame and push as I turned off the camera...it worked. The next time,the lens was extended and would not retract I had to place the camera on its back on a book while I used a small block of wood and a small hammer. It worked camera is working fine. After both cases, it took about 5 shots to calibrate the auto focus.
Jul 07, 2009 | Canon PowerShot G10 Digital Camera
I bet you can't solve this.
We have a Canon A520 and it was having all the symptoms noted. Searched for a resolution on numerous sites including the Canon Support site. While on the Canon Support site, I found an FAQ on "How to RESET the A520". Turn camera on, find and hold MENU button for 5+ seconds until "Reset settings to default?" screen appears. Arrow over to OK and press the SET button. When we did this the battery low indicator showed, replaced batteries with standard alkaline batteries. Everything functions properly, with no additional problems for the past 5 days. I guess the camera just lost its mind and had to be defaulted and rebooted, hope this helps.
Oct 01, 2008 | Canon PowerShot A520 Digital Camera
Camera just stop working
Email Canon with your problem. I had a Canon S1 IS camera. It failed on me in June 2008. It started to display lines across the Lcd screen intermittently, until a week later it completely failed. It would turn on but no display on screen when switched to camera mode.
I emailed Canon and they replied to send it to them and if it was a malfunction with the camera they would repaired it free of charge. I sent the camera to Canon ( Canada) and 2 weeks later they sent me a new S5 IS because the faulty ccd image board was on back order. I am very happy with Canon and would continue to purchase Canon products because of their customer service ....they seem to stand by their products.
Aug 03, 2008 | Canon PowerShot S2 IS Digital Camera
Canon eos 400d
Contact Canon - some makes of lens which are not Canon are not electronically compatible for various reasons, and can actually damage the camera. So, get using the phone and check if it is compatible before doing anything else - but personally, I would not use the lens until I find out
Jul 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Lens cover problem leads to LCD problem
If the pics show up on the memory card, it's just an LCD issue.
Jul 27, 2007 | Canon PowerShot S30 Digital Camera
Canon PowerShot S30 Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
