On my Hitachi Mo# 53uwx10ba I developed a slight double image on about 25-30% of the left side of the screen the rest of the picture is clear and good. convergence goes through its motions but does not correct problem,Have unplugged unit over night,tried different cables..there are manual controls behind front panel that adjust color and clarity but will not will fix proplem ..Please suggest resolution,
Thank you for your time as it is appreciated.
Al
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Needs convergence IC's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
SOURCE: hitachi Mo# 53uwx10ba double image
Please rate accordingly
Thank you
Computerrep
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Right on the money that was the fix!! Thank you is not enough but it keeps me believing that together in this great nation anything can be done if we do it together. strike one more positive for humanity..
AK
Need to find manual adjustment menu
how do i replace the new part for the convergence kit i bought...I have to remove the board but it is link to other board by what i call little bridges and how do you dischage it?
red blue green not aligned
hitachi 53udx10b bows down from top with color ghost
i have a slight double vision in the center of my screen 53in big screen projection help please
have slight double imige on left side
the color is off on my TV. it looks like everything has a reflection
the color is off on my tv. we tryed the majic focus but that does not work. help
We recently moved our hitachi 53UDX10B projection TV about 2 ft. and the magic focus (which is automatic) is not setting right. It skips the blue color focus completely and does not seem to do a thing to fix it. The screen has a 3-D image with the green color forming a sort of back shadow on images. Also, on the left side, the alignment seems to be a bit off. From the research I've done so far, I think it may be a convergence IC's problem, I'm not sure. I live in a small town where the repair shop won't touch my TV. I have however checked to see if any wiring was loose and it all seemed secure. Any suggestions would be greatly appreciated!
I have the same problem could someone help me out. Thanks Dave
I have the same problem. Â It looks like I am looking through a set of 3-d glasses. Â Thanks
I have an Hitachi Ultravision tele, approx 12 yrs old. There is a double discolored image on the left side of the screen. Any suggestions?
I can't believe I found this website. We have the same problem. Our projection tv is about 5 years old and we have had no problems until now. The left side of the picture is showing red double images but the right side is perfect, so annoying to watch this. Our tv is Hitachi #53SBX10B. Can you help us out? Barbara
We have a Hitachi 53UDX10B and on the top left side of the screen is the red line like everyone else seems to have. At first we thought it was our cable connections and have disconnected/reconnected, bought new cables, tried to make adjustments. etc. without any response. I am to understand it is the convergence IC's. Are these expensive? Do they require service or can we do it ourselves?
Iam have the double image problem. I have tried everything
My Red and Blue Focus is slightly off, is there a manual way to adjust this...the "magic focus" is a magical joke!
My Hitachi 53" television has developed a slight 3D effect that blurs the whole screen. I have tried to do a hard reset but nothing has worked. If anyone can help me it would be greatly appreciated. Thank you!!
Left side - same as many others have written - if I tuen it off right away I was able to get it to reset but got more often and now have to call for service - noone will give me a price over the phone only that it will cost $90 nto just come out - seems to me many have stated 5 to 6 yr set same issue and always on the left side out of focus double image - any suggestions
left side 30% out of focus - turn set off right away and sometimes it will fix it for a whiloe but then it happens again and the fix time gets shorter
double image on top
Same problem.
The TV has a doubled vision on 100% of the viewing screen. I've tried the Magic Focus many times. Are there any solutions?
Help Me Please! My Hitachi 50UX27KV has the bowing issue along with double focus problems. Any help will be appreciated.
I developed a double image on about half of the left side of the screen the rest of the picture is clear and good. convergence goes through its motions but does not correct problem,Have tried many things. Seen The previous person thanked your for solving the problem hehe.
Theresa
hitachi 53 projection seeing double image in middle and blue
Double vision on the left side. We unplugged everything and plugged it all back up. We are not sure what the problem is...can you help?
doing same thing, color also bowing
I replaced the ic's but I keep blowing resistor RK42 ?? result is me being unable to move vertical red while doing the manual convergance (i think) any response will be much appreciated. Thanks
I have the same problem. What is the solution?
We have had the conversion board replaced three times since we've owned the Tv. Granted is is 7 yrs old, However maybe someone should look into this recurring problem. Please respond with any suggestions. thanks.
Left side of the screen is blury and the right side is fine.
What can I do to fix it.
Thank you
Im seeing double images. But if i was to go and try to adjust the color when i select that adjustments the double image isn't there its on the other adjustment selections.
same problem on a 52 in hitachi. How did you fix it???
BA
SAME PROBLEM BLUE /RED SHADOW UPPER LEFT HAND OF SCREEN?????HELP
I have the same
I have the Hitachi 53UWX10BA rear prjection tv.I have a double image to the right of blue and red.How can I repair this
I have a HITACHI rear projection tv # 53UWX10BA with a double image to the right of blue and red.How can I adjust the and save money.Thank you.
We have a green and red double on the left side of the screen which just started. magic focus doesn't help. What are likely causes? Thanks
THE LEFT SIDE OF THE SCREEN IS OUT OF FOCUS AND THE MAGIC FOCUS DOES'NT HELP
