I disconnected everything to move my computer set up to another room and now I've connected up again the software says it can't communicate with the scanner . I've also removed and re-loaded software several times but to no avail. Help!-
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Install PC Suit Then
1. Set your message memory to memory card
2. Connect your phone to PC suite
3. Open communicator centre
4. Export all messages, or the messages you want to move to a folder on your computer.
5. disconnect your phone and change messagememory to C
6. connect again to pc suite.
7. Open communication centre and make a new folder called f.x: important messages.
8. mark the folder you've made and import the messages.
9. disconnect your phone from your pc.
10. Within messaging on your phone, you can move the messages back to inbox or leave them in your folder you made.
Hopefully you have now moved all messages from memorycard to C.
Give it a try and let me know if it worked out.
