usually this is from having the load shorted. make sure that the wires are not touching where you plugged them into the speaker. also check that you have the correct load at the speaker with an ohm meter. you should have between 2-8 ohms
i have a dad 1504 and my amp turns on and the green light come on but i dont get any power to my...
(More)
i have a dad 1504 and my amp turns on and the green light come on but i dont get any power to my subs i think my rca are blown on my amp?!
my playstation3 is new, i hooked it up, and it wont go to the menu,it says that the amount of power...
(More)
my playstation3 is new, i hooked it up, and it wont go to the menu,it says that the amount of power to the usb is reached., and that i have to remove a device., could someone tell me what means?
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to...
(More)
What settings should i have my 760 watt pioneer amp set at for amp gain and bass boost in order to have the best sounding hit from the subs?
Hi there, I have rubicon 204 amp., it starts after 30 min when I turn on him and works erratic (1...
(More)
Hi there, I have rubicon 204 amp., it starts after 30 min when I turn on him and works erratic (1 sec works 2 sec doesn't work, etc...). Power led is on, as have to be. Sometimes works OK. So, where the problem is ?
