Dehumidifiers
Problem for Dehumidifiers
Generic problem for all Dehumidifiers
Dehumidifier leaking onto floor.
By kmhupp on Aug 21, 2009
Sears dehumidifier about 5 years old has always worked well. Now is leaving puddles on the floor underneath. Is it done or can it be cleaned/repaired?
Best Solution
posted on Aug 21, 2009
Very Helpful)
VtToolMan
Rank: Guru
Rating: 97%, 665 votes
You should clean off the condensor coils with a vaccum and soft brush. Also, check up inside the area where the condensate drips into the collection reservoir (or goes directly into a hose attachment discharge) to see if something is partially obstructing the water flow and is dripping onto the floor, etc.
You might find that you've got some buildup of dust, dirt, and some other gunk that is mis-directing the water (condesate) that the dehumidifier is drawing out of the air.
Lastly, check the unit to see if it's level, but frankly, I highly doubt that's the issue, based on the 5+ years of good working service for you.
So long as the unit is still running and keeping the humidity in check, (if the above steps don't resolve the issue), I'd continue using it until it finally quits running, but I'd put a plastic boot/shoe mat under it to catch the small puddles of water.
The dehumidifier should draw the small puddles, so it'd be less expensive to get a $4 boot mat than dropping another $240+ for a new unit, as your's seems to be working fine, aside from the occaissional puddle issue.
Hope you find this Very Helpful and best regards!
Was this helpful?
Yes
No
4 people thought this was helpful
Asker's Testimonial
" Great explanation, that sounds very doable. Thanks very much. " - kmhupp
Popular Solutions for Dehumidifiers
Questions and Unsolved Problems for Dehumidifiers
Answer
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if... (More)
Answer
small basement efficiency that is not occupied during cold months, and accumulates mold and paint... (More)
Answer
Fan is running but the air coming out is not hot. How to fix the problem
Answer
when i plug in the humidifier there is no power,no lights, nothing.
Describe your Dehumidifiers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dehumidifier Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
