I have a Samsung HCN4727w. I am not having any problems and never have had any work done on the set. I have stated having some faint lines in the set but nothing major. I am wondering if I should get the service manual and try to clean the inside of the unit. I have no TV repair experiance.
No, have you ever heard the old saying "...don't try this at home."? The problem you're having could be a simple adjustment of the HV (High Voltage) block feeding each of the three tubes. But that voltage is high enough to kill you several time over. It could also be a leaky anode cap which delivers that voltage to the three CRTs. Problem is the adjustments, even if that's all there is, have to be made live. That means the Tv must be on and running. Personally I'd leave this to a qualified tech. The good news is it can be accomplished in a service-call if it's simply an adjustment. And if not the tech can usually diagnose that problem in the same call and if he has to replace the HV block it's fairly uncomplicated.
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thanks for the Help. I figured that would be the case. The set is 5 years old and I am not sure it is worth the $.
" - paulw235
Popular Solutions for Samsung HCN4727W 47 in. Rear
My tv was suddenly stop working. I dont know what to do this. Tv's red light remain red and am not...
(More)
My tv was suddenly stop working. I dont know what to do this. Tv's red light remain red and am not able to turn it off and on.
Samsung HCN4727W will not turn on everything is pluged in & there is power from the outlet...
(More)
Samsung HCN4727W will not turn on everything is pluged in & there is power from the outlet please solve
