Web Cameras
Problem for Web Cameras
Generic problem for all Web Cameras
I have a problem with
By jufitz64 on Aug 21, 2009
I have a problem with my Belkin Router (model F5D7230-4). Every week or so, when I log onto my laptop, I can't get internet access. I was told that the solution was to unplug the modem, unplug the router, wait 10 minutes, then replug the modem and replug the router. It has something to do with the signal from the modem changing periodically, and the router needs to be restarted to search for (and recognize) the new signal? It is a pain in the neck. Is there any way to avoid having to unplug and replug everything every few days? thanks!
Solution #1
posted on Aug 21, 2009
Not Rated)
bob_computer
Rank: Guru  Computer Accessories  Expert
Rating: 87%, 1204 votes
There are a few things you can do to help reliability
You should first make sure that the modem and router are individually
set up correctly.
I do have a guide for that.
Once that is done you should consider giving out proper IP addresses
Big business does this for security and reliability and it is no different for home users
except maybe easier
Read the guide for router and modem first and if any of it may apply
to you then try and do it.
The second part deals with IP addresses and this may well help you
I have a selection of computers laptops servers at home on a small network
It is quite some time since I last had to do any sort of system wide shutdown
Try the following procedure and write down anything you change so that if you need to go back you know what was changed.
Connect ONLY the router to a pc and nothing else
Go to the start menu and select RUN
In the box type "cmd"
Now in the black screen that has come up type "ipconfig /all"
Take note of the numbers that are in 4 groups e.g. 192.168.1.1
Also take note of the name in front of those numbers
Comments:
Aug 21, 2009
- Now do the same thing with your modem
If that too has the same IP as your router in "default gateway" then you need to fix that issue as that is probably a part of your problems.
The fix for router modem conflict is to set the router to use a different IP range.
To do this only have the router connected (by wire) and open an internet explorer page (it will fail but that's ok)
In the address bar type the number you got for default gateway above e.g. 192.168.1.1 and press ENTER
When it asks for the user name give it the one you gave it when you set it up or the default one from your manual
Also give it the password you gave it when you set it up or once again the default one from the manual.
You now need to look for a box that has the number you just used to get into the router.
It may just say IP address or Starting IP or something similar
That is the number you should change. I usually change the third block e.g. 192.168.2.1 as opposed to 192.168.1.1
You should also have some DNS numbers from the checks further up with the MODEM
You should find the DNS boxes and place those numbers in there
Now look for the save settings button and do so.
Reconnect the modem and router. The cable from the modem should go to the YELLOW socket on the router.
Power up the modem and WAIT until all the correct lights are on.
Then do the same with the router.
Now power up a pc and check that you can surf without problems
If not then the problem may lay elsewhere. Go back and re-check.
Aug 21, 2009
- Now to issuing IP addresses and why.
The computer has to knock-on the routers door and ask for directions home as its address changes evrytime it leaves home (switched off)
You are going to give it a permenant key to its own door. Write down all that you do once again.
The same applies to both wireless and wired connections.
You may get an occasional error regarding the ip address already being assigned tell it to ignore and go ahead.
Call up your control panel and select Network Connections
If you have more than one don’t worry
Right click the first one and select properties
Scroll down to Internet Protocol (TCP/IP) highlight it then click properties
There are boxes here where you are going to type numbers.
Click the "Use the following IP address"
If you changed your router to lets say 192.168.2.1 Then I would use 192.168.2.10 as the first number
The second box is 255.255.255.0
The third box would be 192.168.2.1 (same as your router address)
The two numbers at the bottom can be got from the numbers you wrote down early on when you just had the modem connected
E.g. 207.147.239.12
207.147.239.200
Now click OK
Aug 21, 2009
- If you have more than one connection available then go to the next one and do the same EXCEPT the first IP
I would use 192,168,2.11. The rest would be the same as before.
Now move on to the next computer and do the same again but this time in the first box I would jump by ten so the IP would be 192.168.2.20
Again if it has more than one connection do the same as above and advance the number by one in the top box
Next machine same deal advance by ten. Once you have all your computers done then shut EVERYTHING down
If your problems are mainly wireless related the next part might be of use.
It is more than possible that the location of your router or co channel interference is causing disruption.
If its channel interference try setting your router to auto for channel selection.
If you are not getting any more than a 10mb connection to the router consider moving the router
It may be a problem with the windows wireless config
Aug 21, 2009
- to turn of wireless zero config open control panel, click administrative tools, now services, then scroll down to wireless zero config.
Double click on it then click stop. Then set the service to manual. Make sure you click the APPLY button before hitting OK. You can now close the rest of the windows.
I would suggest at this point you also do a shut down and restart.
What you have just done is tell windows to stop messing about looking at other peoples wifi to see if it fancies something better (sound familiar ?)
You told it that it only has eyes for you ;-)
If you have any problems use the information you wrote down to back step to a working point and then double check from there
I know this looks like a lot to do but for most of us with more than a couple of computers at home it is usually worthwhile
Was this helpful?
Yes
No
Popular Solutions for Web Cameras
Questions and Unsolved Problems for Web Cameras
Answer
web cam that works with vista 64 bit
Answer
We are looking for a basic web cam for outside use that we can record/monitor from a computer. Any... (More)
Answer
how can i install A4tech Pc cam without cd installer
Answer
hello, i purchased zebronics eagles view web cam just 10days back,but when iam using it with my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Web Cameras:
Top Web Camera Experts
Rank: Guru Guru
Solutions: 14870
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Web Camera Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
