Question about Refrigerators
GE refer Model #TCS18PADBLBS Bottom freezer
Noisy fan in the freezer compartment. Pull the refer out, unplugged it and cleaned all the dust possible on the fan and "grates". Looked nice when done. Still had that "bad fan" noise as the freezer cycled about every 5 minutes. I can find that fan without tearing everything apart.
I left the door open to long looking for that fan and now the frig (compressor?) has shut itself down.
Two questions 1. will the compressor reset itself and start working again? 2. where is that freezer fan?
Thanks for your help
ed
I had the same problem, but it was ice that had formed around the fan housing. I had to take the cover off the freezer back and chip out the ice. Now no more noise!!!
Posted on Nov 18, 2009
    Sergeant:
    Champion:
  • 262 Answers
The compressor should reset it self and the fan you just have to dig behind the rear panel for it chances are the blade is rubbing the shroud
Posted on Dec 03, 2007
I have a GE Adora Model DSHS9NGYBCSS where the Refer side doesnt get cold enough but the freezer is working fine. I replaced the freezer side temp sensor on the top of the coil also the damper assy
Check your fan on the back of the unit near compressor and the fan that turns on while the door opens.Clean out all dust also.Make sure food is not blocking circulating inside
May 09, 2018 | GE Refrigerators
Compressor not working after performing maintenance ( vacuuming out condensor coil/ fan/compressor compartment )
If you have a start relay , remove and shake - if you hear anything it is toast. with a cap either use a cap tester or just replace it and cross your fingers.
Mar 30, 2017 | GE Refrigerators
I have a GE PDS22S refrigerator. The surface of the unit around the front of the freezer compartment is extremely hot--the front surface between the refrigerator and freezer is so hot I could not hold my...
My older frost free GE Profile gets VERY hot on the sides and on the top during part of the cycle.
Is your temp indicator picking up the heat from the cycle? Check actual temp using a thermometer...hardware store should have one.
Are doors competely closed on the unit? No Food or plastic wraps/bags in the way?
Is the fan working properly, not squeaking or squealing?
Mar 23, 2017 | GE Profile PDS22SBRR Stainless Steel...
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
It's making a loud running noise
The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Howling noise from freezer fan, GE side-by-side
Replace the fan, Remove the evaporator cover in the back of freezer, and probably another cover for the fan. Unplug your refer first. Usually their are two screws holding the fan bracket to the wall or mount. disconnect the wires, and replace. Their is a newer model evap fan motor that does not have wiring terminals to disconnect, it is hard wired together and you have to practically remove everything in the freezer compartment to get at it. You have to cut wiring and splice the new fan motor in. Fairly tough job. Usually an evaporator fan motor bearing fails from the refer being moved or in storage for a few days at least with the doors closed and the unit unplugged. This allows all that moisture that was in the freezer to get into the metal parts of the fan motor and cause this problem. To prevent this always block the doors open if your refer is going to be off for a few days. This will allow the unit to dry out without damage. Sometimes it was just a bad motor from the factory. Good Luck, Appliance Specialists
Dec 17, 2009 | GE GSF25XGR Side by Side Refrigerator
Clicking of Ge Model PDS22SBRBRSS; serial No; DL047209
IF the below mentioned information does not help, then contact a elextrical engineer worksman who can check the circuit board as it might also cause a short cicuit.
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
May 31, 2009 | PDS22SFS Stainless Steel
GE side by side Refrigerator makes LOUD SQUEAK when running
Mar 24, 2009 | GE Refrigerators
GE fridge runs continuousely
Simple! The replacement fan ran the wrong way forcing air circulation the wrong way. Fortunately it was possible to reverse the moter shaft.
Dec 11, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
GE TCS18PADBLBS Freezer
if the drain line is frozen or clogged then you have to remove the back freezer panel and with a hair dryer at the bttom of the evaperator coil thaw the ice that is built up in the evaperator pan ouce you have it thawed you can pour water into the evaperator pan and it will run into the drainpan if you pour water into the pan and it does not run into the pan keep thawing
Apr 24, 2008 | Refrigerators
Refrigerators Logo
420 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
