Question about EliteGroup PT800CE-A Motherboard
SATA Problem with Maxtor 250 GB.
Bought a new Maxtor but XP crashes when trying to install new OS onto Drive.
    Scholar:
  • 58 Answers
You need to post more information.
  • How does XP crash?
  • What error messages does it give you?
  • Did you double check your cables and BIOS settings?
  • Check out the MOBO manual and look for directions on the SATA ports, and boot device settings in the BIOS
Posted on Dec 03, 2007
SOURCE:
I AM LOOKING FOR LATEST DRIVER DRIVERS FOR MAXTOR DiamondMax 21 SATA 250GB Hard DRIVE FOR WIN XP-PRO PC
The latest drivers and support would be available from the Seagate website. The Seatools utility is an excellent tool that is also available.
http://www.seagate.com/www/en-us/
I hope this helps.
Sep 03, 2011 | Seagate 250GB Maxtor DiamondMax Plus 21...
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
How 2 install in my new hp also have a burner on same cable burner works but both dont work 2gether
a dvd burner on same bus as a hard drive..the cable needs to go to hard drive first then the dvd drive..is that the case? also, if it's SATA, the order on which cable comes from the board to hard drive SATA 0 is critical
Dec 06, 2009 | Maxtor (6L250R0) 250 GB Hard Drive
Windows XP can't see SATA Drive
turn of Ahci mode from your bios settings and if there is also some sata configuration then turn those off also then check...
Dont forget to rate
Sep 08, 2009 | Maxtor MaXLine Plus II 250 GB Hard Drive
My Maxtor suddenly stopped working, no more power. I took it out of the hardcase and there's a brown stain (burned) on the SMOOTH chip. Any chance on recovering the data? Thanks
You can buy another caddy with all the electronics for the drive inside, so basically you continue to use your drive in a new caddy and no need to recover data.
I lost a drive once and now backup all my important video, etc. onto dvd as a precaution.
Aug 14, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Cant load xp onto sata HDD
To use XP with a SATA drive you'd need to use the HDD disc software first as XP didn't come with preloaded SATA drivers. This is what is preventing you from installing XP on the drive. Once the driver is loaded you should have no problem. If your new hdd didn't come with a disc then you can download it from the hdd manufacturers website under the support link. Hope this helps.
Jul 12, 2009 | Seagate (ST3250824AS) 250 GB Hard Drive
Installing new sata drive in HP pc
a clean xp installation does not recognize sata drives at all. you can either use nlite to build a custom install cd, press f6 during setup to load additional drivers, try to change your sata mode from native to compatible in your bios or use your restore cds.
Mar 18, 2009 | Western Digital WD2500BEVSRTL Scorpio...
Vista installation
try updating the os using windows update
Sep 20, 2008 | Computers & Internet
Windows XP will not pickup my 2nd hard drive (intermittent fault)
most likely it is getting ready to crash, remove your files and replace the HD very quickly.
[email protected]
Aug 16, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
EliteGroup PT800CE-A Motherboard Logo
55 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
