Nintendo Game Boy Advance Console
Problem for Nintendo Game Boy Advance Console
My daughters leapster 2 freezes and has to be
By leanne71087 on Aug 21, 2009
my daughters leapster 2 freezes and has to be turned off then back on to fix the problem and now the screen has changed collors and is barely readable how do i fix these problems
Solution #1
posted on Oct 13, 2009
Not Rated)
aliciacain12
Rank: Master
Rating: 75%, 4 votes
My 3 year old daughter has a princess leapster 2. Put new batteries in and still will not turn on. I called customer service and they are willing to replace it even after the warranty has expired. Here is the Customer Service #800-701-5327
Was this helpful?
Yes
No
Solution #2
posted on Aug 28, 2009
Not Rated)
bruce508
Rank: Wiz
Rating: 93%, 25 votes
That sounds bad. I'd check to see if you are within warranty coverage. Sometimes tech support will help you a bit even if you are not.
Most likely, the unit was dropped or else exposed to moisture. If it was dropped, a printed circuit board or similar may have cracked. That's sometimes repairable, but a difficult thing to do even for an expert with good equipment.
On the other hand, possibly a cable or connector inside, particularly one connected to the screen has come a bit loose from being dropped. You might be able to fix that by taking the unit apart (being careful to remember how things fit) and re-seating all the connectors, i.e. disconnect each one and then push it back into place firmly, though not really forcefully. The trouble is that in order to take the unit apart, there will likely be a screw under a label or something similar that is going to break your warranty by opening it. So you probably don't want to do this if the unit is in warranty.
Another possibility is that the unit was exposed to moisture. If so, you can try what I said in the last paragraph but also look for water stains or similar. If you find any, they sometimes leave a residue behind that can cause a short. Sometimes, even a bit of water can last for a long time if trapped under a part or connector. You can clean small water stains with some isopropyl alcohol on a Q-tip. If you think there might still be moisture in the unit, try blowing hard at it while it is open from different angles. You might also try blowing a hair dryer at it and through it for awhile. If it becomes too hot to touch, you have the hair dryer too close.
Warranty repair is by far your best choice. The other techniques may work but unless you specifically spot the problem inside you may not be able to correctly diagnose it and fix it.
Was this helpful?
Yes
No
Popular Solutions for Nintendo Game Boy Advance
Questions and Unsolved Problems for Nintendo Game Boy Advance
Do you recommend Nintendo Game Boy Advance Console?
Answer
Answer
I'm trying to setup the XBox 360 to play Little Leaps video games for my daughter. I cannot get her... (More)
Answer
my pokemon leafgreen is not saving my file anymore
Describe your Video Game Consoles problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
