Question about 2wire (1000-400108-001) Router
Wireless security I have a blanc wireless router. My internet connection works fine ... the problem is that it's open to other to use. How do I secure it
  • Anonymous Dec 03, 2007
    Please describe the specifics of your problem below. We'll add
    your post as a comment to Bernie-b's Wireless security problem, and notify you when a new solution is offered
  • 556 Answers
A review of the capabilities of the specific router and wireless adapters must be performed to determined to determine the options to secure the router from unauthorized access.
Again depending on the available hardware some option I have used include: from weakest to strongest, in my opinion
Hiding the SSID (name) of the router and requiring it to be entered on allowable machines wireless configuration to gain access
Use of WEP encryption - a password requireent that also scrambles the data preventing unauthorised access -- there is some weakness to this method based in the implementations and length of keys
Use of WAP or WPA encryption similar to WEP encryption except that the weaknesses of some of the implementations was prevented in the standards also I believe this supports longer keys.
Having the Router verify the MAC addresses loaded into the wireless adapter cards it communicates with -- is often considered a problem because every new card must be configured into the router when replaced or a friend comes over and needs access to your network but more difficult to fool.
In general I prefer WAP encryption over WEP if all devices will support it. Personally I also tend to hid the SSID name of the router too.
Posted on Dec 06, 2007
I am a Comcast customer with high speed internet. I am trying to get my wireless router to work on my lap top (Toshiba). The lap top will work if connected to the modem directly. However, when I try to...
to configure the netgear router and to secure its network. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.then your all set for wireless connectivity.
Aug 12, 2011 | NetGear WGR614 Wireless Router
My Atheros AR5007 will only complete a "Local Connection, No Internet Connection" to a NetGear N600 Dual Band Router when Security Options (WPA2-PSK (AES)...ect) are selected on the Wireless...
Since the connection works without the encryption settings, it is NOT a driver issue. It sounds like a missing wireless network security setup problem. So assuming Windows (Mac OSX is similiar):
  1. Connect a laptop/PC to the NetGear via ethernet. It saves on some aggravations later.
  2. Connect to the NetGear and restore the security settings, and remember your keyword.
  3. On your computer, open the list of Wireless Networks (usually Start->Control Panel->Network(ing)->Wireless Networks). The menu sequence might differ slightly, depending on which Windows you're running.
  4. Find and click on "Manage Wireless Networks" (or words to that effect)
  5. Right click on your wireless network's name to get the drop down menu, and select "Properties"
  6. Find a button or tab related to "Security"
  7. Under Security Type, select WPA2-PSK (or Personal)
  8. Under Encryption Type, select "AES"
  9. Under Password (or Security Key), type in your router's WiFi security key word. You may have to log back into the NetGear and find the keyword (yours) or the alternate (gibberish) form.
  10. Save the settings
  11. If you're connected to that wireless network, then disconnect
  12. Try connecting to the wireless network again. It should work this time.
Feb 23, 2011 | D-Link Computers & Internet
I have a belkin.4bda router connected to my laptop from my pc which normally works very well, however from time to time my laptop will not allow me to connect to the internet saying that my security key...
The PC connects to the Internet because it uses a network cable that is attached to the router.
The laptop connects to the router with a wireless connection, you most likely have enabled encryption on the router's wireless settings and if the laptop's wireless card has not been configured with the router's encryption settings, then it cannot connect to the router via the wireless until you enter the encryption (security) key.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2011 | Belkin Basic Wireless Router
I have got username(admin) password)1234) wanting
Please connect the Netgear Router to your Laptop with a Ethernet cable.
In order to connect Netgear Router to your Laptop please follow these steps:
STEP 1 : If you look at back of router there are 4 LAN ports that are together and 1 WAN or Internet port which is alone. Connect the Internet cable ( provided by your Internet Service Provider) to WAN or Internet port of router .
Now take another Ethernet cable and connect one end of the cable to any one of 4 LAN ports and connect the second end to your laptop. Now please turn on the router.
STEP 2: You can see Power, Internet, Wireless and one LAN port light there on the router. Now come to computer and try to open the router login page.
In order to open the router page , you need to open your Internet Explorer and type 192.168.1.1 in the address bar.Now it will ask for router login information .
Username = admin Password = password
If it doesn't work please try to check the IP address of your computer ( In order to check the IP address of computer, Click on START menu , goto RUN and in RUN Window please type cmd. A black window pops up under this please type IPCONFIG and check the ETHERNET adapter IP address.
Now try to open the router page using this IP address.
STEP 3: Now on the router page you can see number of option on the left side. In order to change or secure the router for wireless connection please click on WIRELESS SETTING option under BASIC SETTING.
Under the SSID : type the name for your wireless network ( of your choice) CHANNEL : it should be 11 or 6 . Security : select WPA-PSK and under key please type any password of your choice ( it must be 8 characters atleast)
Please save the setting.
STEP 4: Now unplug the Ethernet cable from your laptop. Under the wireless networks , you can find your wireless network name . Just select it and click connect on. It will ask for security key or network key please type the same password that you have created for wireless setting.
Now it will connect you to your wireless network that is secured now.
Dec 09, 2010 | NetGear WGR614 Wireless Router
When initially setup the router worked fine. However, after a computer crash and re-install, the desktop pc cannot find the router even though it is connected by Ethernet. Laptops will connect to the...
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 09, 2010 | Belkin Wireless Play Router (F7D4302)
I want to secure my wireless conection
to secure your wireless register for www.opendns.com it can help secure your router wireless internet try it now
Jun 18, 2010 | Linksys WRT160N Wireless Router
Can't connect
The only way to get the security code is to access the router's setup page. On your wired PC, open Internet Explorer, type http://192.168.2.1, type in the router's password. Go to Wireless settings and look for wireless security, you can see the wireless code there.
Jan 20, 2009 | NetGear WGR614 Wireless Router
Securing my wireless
if you are talking about the wireless security, by default it's not enabled so you need to enable it by going to the router's setup page. here's how: open a web browser (e.g. internet explorer, firefox etc) then type http://192.168.1.1 on the address bar. it'll promt you for the username and password, leave the username blank and type admin (default password)on the password. you will then be prompted with the linksys page, go to the wireless tab then look for the wireless security subtab. there you can enable your wireless security.
hope this'll help you and just ask me if you have other concern
ciao!
Oct 21, 2008 | Linksys A+G WRT55AG Wireless Router
No network
The Wireless Security of the router doesn't match your laptop's wireless settings. Make sure you configure the wireless security password correctly on the laptop. If you don't know your wireless password, try these steps:
-Connect your laptop hard wired to the router.
-Open Internet Explorer and on the Address Bard type http://192.168.1.1 press enter.
-It will prompt you for username and password. By default, there's no username and on the password type admin and hit OK. If admin didn't work, type your own password for the router.
-When you get to the Setup page, click on Wireless Tab, then click the sub-tab Wireless Security.
-Look for Security Mode. If Security Mode is WPA-Personal, the Passphrase is the wireless security key that you need to enter on the laptop's wireless settings. If the Security Mode is WEP, the WEP Key 1 is your wireless security key. Connect to the wireless network and type it in. That should solve your wireless connection problem.
Sep 06, 2008 | Linksys Wireless-N WRT150N Router
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
2wire (1000-400108-001) Router Logo
217 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
