I'm pretty positive that the iPod will 'just work' when you plug it in to a device like that.
Since you said it was working perfectly a few months ago, I would suggest you clean it out as best as you can. Take it apart, blow it out, clean the connectors with isopropyl alcohol (the highest % you can find) and clean the connectors on the ipod too.
Do you perhaps have another device to test the video output on the iPod on? Do you have another iPod you could try in your V55? Try switching things around and see if you can narrow down the problem.
it is 100% sure that your tube is ok.
there are few problems in different section like
Thanks V1... after some "troubleshooting", I realized... that I shouldn't even be allowed to post this, but I should own up to it: i had the iPod turned on BEFORE I put it in the viewer. Once I turned it off and let the viewer power it on, it all worked. I feel extremely dumb! But, as frustrating as it was, there was nothign i saw on the www that addressed this.. or that there needs to be a specific order to the power cycle.. Hope my stupidity helps all out there :)
