Question about Bose Lifestyle 28 System
Volume Hi, The volume on my system gets stuck. It will not go up or down. When using the remote you can see on the system that the volume level is changing, goes from 30, 40, 50, etc., but the sound coming out does not change. This seemed to come out of no where. Can anyone help?Thankstgunn
  • 456 Answers
Heyya first check out the speaker wires and then try
Posted on Dec 03, 2007
SOURCE:
I have a ge gtd 120 home theatre surround sound.for some reason, my volume is stuck on one level.. I haven't had a remote for it for a while, just used the knob to adjust the volume.someone plz help!
Unless the system has some kind of automatic volume control on it, that can only be adjusted by the remote. I think you might have a faulty volume/tone control circuit. These days many amps have a single IC that will control the volume. If that goes the volume can get stuck on one level. Since the control knob you are turning is simply sending a signal to that IC. So if the IC has died the signal is not being received.
If you want to repair it yourself just follow the wires back to the board from the volume control. You should see a large multi pin black box that if your lucky is marked on the board volume control.
Jun 10, 2016 | GE Audio Players & Recorders
Sansui platinum plus tv
Are you using a remote control or the switches on the TV?
If using a remote;
First turn the TV off at the power point then wait for 10 seconds.
Then turn the TV back on
Then attempt top adjust the volume using the manual settings on the side or bottom of your TV, if that works then you may have a remote that either needs new batteries or does not work.?
Can you turn the TV on and Off with the remote control?
Can you change channels with the remote control?
If you can do both the above it would appear that the remote is working OK.
Does this fix the problem?
Jun 30, 2014 | Televison & Video
I cannot get the volume to go up or down...it is stuck at one level. I have just replaced the battery, and all other functions work fine. The remote is about 2yrs old.
If you have other (Universal) remotes in your home try programming one of them to operate your Bose.I have a different Bose system for my TV and can operate the on/off and volume from my universal remote. The code I use is 440, I show another code of 302 that may work.
Nov 28, 2010 | Bose Wave Music System Remote
Have an Hitachi 60sx12b. the sound meter bar stays on. can manually adjust the sound up but will go back down to 0. tv remote or sat. remote doesn't work at all. Please help
It sounds either volume down button is bad that turns volume down on its own or system control chip got defective and decreasing volume level.
Press volume down button on tv front and check is it working properly.
Let me know to find out further info to solve the issue.
Thanks.
Jun 05, 2010 | Hitachi Televison & Video
While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
Jan 30, 2010 | Onkyo TX-SR703 Receiver
Need to use remote to change volume
this aiwa equipment failure is common, is that the contacts within the volume botton causing misreading get dirty when going up or down the volume. you have two options the first is to buy the button or pull it out and clean it is not difficult. bye
Jun 14, 2009 | Aiwa NSX-A999 Shelf System
Tv ws-65511 volume stuck
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Volume
I had this problem and checked the main wire going from console to bass unit, it was loose from where I had moved the unit to insert another device (RCA Jacks). Apparently if the wire from the unit is loose, it over - rides the volume and by default adjusts it to 30. Additionally, I reset the system console and bass unit console, during this process. Try this, it might fix your problem.
Dec 03, 2007 | Bose Lifestyle 28 System
Bose Lifestyle 28 System Logo
301 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
