Question about Sony KV-36XBR400 36" TV
T V Shuts off by itself, after a couple of minutes.
I have a Sony Triniton 36" TV model # KV-36XBR400, Manufactur date November 2000. The TV has a great picture and the sound quality is great, but some days it will work fine, but then other days it will shut itself off after a couple of minutes. You turn it back on and the same thing it will play then shut down again after a couple of minutes.
  • navapi Dec 16, 2007
    KV-36XBR400 shuts down, four blinks on front led.  Had to lug unit to Aut. Sony Repairman.  Said it was a "D" board problem.  He sent for a Refurb. unit from Sony.  Installed refurbished D board from Sony.  Brought it home, plugged it in, noticed picute was fuzzy and within two hours, TV went out again.  Received 4 blinks on LED on front of TV.  Unplugged unit to reset, then turned it on again.  But within a day, it went out completely with the same 4 blinks on the front LED.  Called Sony Repairman, brought it back to his shop and this time--he said he was done with the unit.  He refunded my 439.00 dollars, and I now have a 240 lb paperweight.
    Reviewed various posting of "fix its" and have not read any with my problem.  Perhaps you have a solution.  Love this TV, and it cost $2600.00 new and is HD ready.
    Trouble in Wildcat Land
  • Sony Master
  • 586 Answers
here is some tips for ur TV which blinks 4 time.
1 Probable
Cause
Location
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
Detected
Symptoms
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
stopped.
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Posted on Dec 25, 2007
SOURCE:
Sony triniton model kb-36xbr450 keeps turning off by itself
There is some short circuit with the main board of this TV. Contact any experienced service technician to get it repaired. It is a skilled work, that a user can't do.
Aug 10, 2012 | Sony KV-36XBR450 36" TV
I am having problem turning my Sony kv-x2182 TV
Visit this site "Electro-help". You can get details from it. Can search it either by Google or Yahoo itself. Don't forget to type in 'hyphen' in between words, as site name is thus.
May 08, 2012 | Sony KV-36XBR400 36" TV
We have 7 blinks on my KV-36HS420 Sony Wega Triniton. It will come on with only 5 seconds of audio and then shuts itself off with 7 blinks. What part does it sound like needs to be replaces
The power supply in all likelihood. Not something you can do. Any tv repair can take care of it but will likely charge $25-30 for an estimate. They have to spend a bit of their time to check it out. The cost of the estimate will go towards any repairs.
Aug 11, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony KV-36XBR400 won't power up. It just clicks as it tries.
this will require a technician.several components will cause this. usually the horiz.
output transistor and flyback transformer in the
high voltage circuit.
Jul 31, 2009 | Sony KV-36XBR400 36" TV
User Guide or Manual:
If you require KV-36XBR400 user manual, you can download it from Sony Support.
And if needs another one, let me know exact model number to provide you.
Nov 20, 2008 | Sony KV-36XBR400 36" TV
Sony kv 36xbr400 - Won't stay on
Problem is in the secondary power supply which provides power to high-voltage and scanning sections of main board. This is called BOARD D, and has the high-voltage section, flyback transformer, and control IC on it.
Can't be fixed by user, needs service tech and new part, around $300
Oct 12, 2008 | Sony KV-36XBR400 36" TV
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony KV-36xb1400 convergance Problem
Its not matter of service code only. You also need service data to fix it. But question is, how data is being corrupted? It seems hardware failure in your TV set.
Jul 31, 2008 | Sony KV-36FS100 36" TV
TV will not stay on for longer than 5 minutes
This sounds like the shutdown circuit is shutting down the TV due to an over current condition. This overcurrent condition is caused by a component in the HV section drawing excessive current. the 5 blinks is a visual indication of the problem.
Sep 08, 2007 | Sony KV-36XBR400 36" TV
Sony KV-36XBR400 36" TV Logo
190 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
