Hppavilion zv 6000 laptop
Not able to access wireless. My wireless button does not light up when pushed to activate.
    Problem Solver:
  • 8 Answers
Had this problem with at least 50 people at work with this model.
HP sent out a bad patch for this computer's wireless card. You have to go into device manager then roll back the driver to the previous driver.
If you keep allot of restore points, check the calendar for when this driver was updated.
If you dont have a driver to roll back to, then uninstall the wireless card and then restart the pc.
When the pc restarts, it will auto detect a wireless card and install the generic Microsoft drivers for a wireless card.
Call me crazy but at work the Microsoft drivers worked 99% of the time. If they did not work then it was a hardware problem which HP has to fix.
Posted on Jan 12, 2008
2 Suggested Answers
  • 8 Answers
SOURCE: hppavilion zv 6000 laptop
just reinstall your wireless software.
Posted on May 31, 2009
Notebook won't connect wifi
Hi, assuming your laptop is switched on.
Above the keyboard on the right side are the three 'Easy buttons'. The one on the left is for the wireless function.
Push this button to activate or deactivate the Wireless LAN. When you activate the wireless LAN function, it will search for a wireless LAN signal automatically (assuming you have the wireless LAN driver installed). Just below the screen on the right side is the Status LED Panel, which show six icons, each with its own LED. The first one on the left indicates Wireless LAN status. When the LED is displaying a green light, it indicates that the system is accessing data from, or retrieving data by wireless LAN. So whenever you press the Easy button, you should see the green status light come on or go off. To repeat, if the light is not on, you need to press the Wireless LAN 'Easy Button'. NOTE! If you can't get the button to come on, you will need to re-install the Wireless LAN driver.
Jan 16, 2014 | Averatec 5110H Notebook
How i do keep my wireless switched on
There should be an option to "automatically connect" when it detects the network. Look for a checkbox.
create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection
below that will be change search defaults click on settings you will see all search providers you
have if dont need any of them you can disable or remove them
Power on the laptop computer and wait for the operating system to boot before proceeding.
Right-click the wireless icon in the lower right corner of the desktop.
From the pop-up menu select "Enable."
This activates the wireless Internet options but it does not turn on the wireless receiver.
Push down on the wireless button or wireless switch on the top of the keyboard.
After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection.
Right-click the wireless icon again.
From the pull-up menu choose to view all available wireless networks in the area.
A window appears with all the networks your computer receives some sort of signal from.
Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet.
you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings .
click start Control Panel - Network Connections - right click on 'Wireless connection'
(or similar) and click 'enable'.
right click on the network in the bottom toolbar select open network sharing center
you should have the options to either connect or disconnect or set up a network connection
this will vary depending on your operating system
hope this helps
Sep 26, 2012 | Computers & Internet
Were do i turn on my wireless connection on my laptop?
INSTALLING THE WIRELESS LAN DEVICE DRIVER
Please follow the procedures below for installing the Mini PCI Adapter driver:
Installing Wireless LAN driver for Windows XP
1. Click the Start button and then click Run. The Run dialog box appears.
2. Click Browse button and specify the directory as "E:\Drivers\Winxp\Wireless LAN\setup.exe"
3. Click "OK" to implement the setup program to install this driver.
4. Click "Next" twice to continue the installation.
INSTALLING THE LAN DEVICE DRIVER
• Wireless LAN Access When LED turns on indicates that the wireless LAN module is activated. When LED lights off, it indicates that the function is disabled
MUST BE A SOFTWARE ACTIVATED SWITCH
Jan 21, 2011 | Everex StepNote NC1500 Notebook
How do i turn on wireless on acer aspire 4720z ?
The far left button below the start button (middle, top) is the wireless button. It seems this button is finicky and the led doesn t always light. Open the control panel and access the Windows Mobility Center at the bottom. The wireless feature enable button will not be accessible if the wireless button is not activated. While on this screen press the far left button that has a dish network symbol and keep pressing it over and over until the button on the mobility center panel is enabled. This is the only clue you will have on whether the button is on or off.
Jul 02, 2010 | Acer Aspire 4720 Notebook
May 31, 2009 | HP Compaq Presario V2555US Notebook
Hp pavilion zv 6000 no keyboard or screen
Please have a look at this article by clicking here
You may need to update the BIOS
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Mar 20, 2009 | HP Pavilion ZV6000 Laptop
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
Activate Wireless netwerk connection HP Compaq 6710b
have hp computer,unable to switch on wireless connection.im just a novice.HELP
Jul 08, 2008 | HP Smart Buy Notebook
Computers & Internet Logo
217 people viewed this question
Alun Cox
David Payne
David Payne
