StarTech.com StarView SV431USB 4-port KVM Switch Logo
Posted on Aug 21, 2009
Need codes for star view 4
I have the the box super usb star view 4 need codes to get the sports an movies channels can anyone help,thank you
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
305
Points
2answers
Starview super.... NO CHANNELS
try this it has worked for me im back on enter your nos as folows
N.T.L. PURE
54 01
A9 5D 4E FE 20 E1 2D 03
88 6B 69 7E 94 B6 BB 1E
then do a scan of programms it has got me back on i have a eurovox which is similar input good luck
22helpful
8answers
Need new codes for star view box super on virgin/ntl
this box updates automatically. virgin have found a way to cut the signal off. you can press menu then numbers 1570 and go onto nagravision menu and it will tell you how to enter the code.
if you can't get this menu then you havent got the right firmware in the box. hope this helps.
4helpful
2answers
Star view 5 start up (Virgin Media)
Press menu on handset.Standing on installation press numbers 1570. Changes to nagravision. Press OK. This will get you to key providers. Scroll right till you get to telewest/virgin.Use handset to put codes in 00 first then 01.Press store after each set of codes.
Telewest/virgin codes updated 12/10/09
00 - CF 53 OC 33 79 61 71 85
01- 52 5E 8D 45 FC 75 F6 4A After this press exit to the start.
You might have to do installation.
Press menu. On installation press 1668.While on telewest press OK. It should input all channels.
Just got a new starview the box super usb not getting all the channels tried 1570 to change code does anyone no the next step
sky sports and sky movies have moved to nagra 3 so there probably won`t be a fix soon/ ever for those!! have you used the V1.12 file yet? you must d-load it to a usb stick and then flash the box with it(insert at the back of the box,but make sure the box is switched off from the back).hope this link helps
http://dooby2oons.googoolz.com/the-box-usb-starview-4-f11/starview-the-box-usb-update-guide-t253.htm#1382
12helpful
4answers
The box super usb 21st Aug 09
Below is a letter from a supplier of Starview which they have been sending out to their customers
Hi Folks - Hope All Is Well.
It Has Recently Come To Our Attention That A Few Of Our Customers Have Recently Been Experiencing What Seems To Be Power Supply Related Issues With The Starview 4 USB Receiver. This Infact Is Actually A Software Related Issue & Is NOT Due To A Premature Hardware Failure Or A Premature Power Supply Failure.
As A Precaution, We Are Requesting That All UK & EIRE Owners Of The Starview 4 USB Receiver Upgrade To the Latest Software Version With Immediate Effect To Prevent Any Issues.
This Is In Your Own Interest & Must Be Adhered To Ensure All Warranties Stay Valid.
The Software Must Be Copied To A Good Quality USB Memory Stick & Can Be Installed By Pressing A Few Buttons On The Remote Control.
Please Do Use A Good Quality USB Memory Stick, To Prevent Any Firmware Corruption On The Receiver. This Will Prevent The 8882 Error From Being Displayed On Receivers Front Display Panel.
Firstly Download The V1.12 Software From This Link:
V1.12 Software
Select The Blue Coloured "Download Now" Button
1helpful
3answers
The Box, The Box Super, NTL area, not all channels coming in.
Not 100% certain that this'll work but this is what I did & hopefully it'll work for you too - good luck :-
Subject: Star View 3 The Box Super when channels discappear ;o) 1. Press menu then Factory Setting & Enter code 0000 to reset. 2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on 3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o) Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess & press download !!!
1helpful
How to put code in for the box super usb/starview 4
C & W 5C 01 09/01/09
00= 7D 9B 0E 8B 69 3F E7 34
01= EF 38 DF 11 3D 85 FE 2F
Telewest 5A 01] 23/12/08
00= E7 D3 69 2E 6F 38 EA 78
01= E8 C9 E5 6E B0 49 53 F5
NTL 54 01] 09/01/09
00= 2E E9 B1 3F F7 F8 53 B2
01= 97 9B 22 E0 5B 13 B1 C7
2helpful
5answers
Starview 4 thebox super usb
hope this is of help to you if not let me know .
press menu.
press 1570.
look down list to make sure EMU is set to ON . press ok.
code screen service provider tab should be 5A01.
00. go to the bottom of screen and change the codes saving each code entered.
go to the 00 tab and press right to 01. go to the code tab and change codes saving each code as entered.
0.C0 F6 61 87 91 F9 67 57
1.F0 83 35 E5 28 40 49 B2
Top StarTech.com Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
