Question about GE 28021EE2 Phone
GE 28021ee2 digital cordless phone says "HANDSET NEEDS REGISTRATION". It worked earlier today.
SOURCE: handset wont register
Unplug the battery and try again. Worked for me.
Posted on Jun 17, 2007
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Posted on May 30, 2008
SOURCE: GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
Posted on Jul 09, 2008
SOURCE: Lost manual for the GE DECT 6.0 Cordless Digital Phone # 28115FE1
GE 6.0
Somehow I have put "DO NOT DISTURB" and now I have no ringer
Any solutions or suggestions?
Posted on Aug 14, 2008
  • 6 Answers
SOURCE: registering handset
If all else fails, read the instructions.
"4. Place the handset in the base cradle. The charge/in use indicator turns on, verifying the battery is charging. The unit will take 20 seconds to register and verify its security code. READY shows in the handset’s display."
Posted on Jan 13, 2009
  • 1606 Answers
SOURCE: I have a new Uniden cordless phone. The handsets
You can downlaod the manual from uniden in pdf form.
the -4 or -5 refers to how many handsets you set. The 1580 is the actual model number.
To register I think all you do is place them on the master pad once then on their own charger stations. On some models they come all done so you just plug them in charge them up and use them.
Posted on Mar 23, 2010
0 characters
1 Points
Dual handset ge 21008ge2-a handset needs registration suddenly came up for no reason. we've had the set for several years
Follow the registration instructions on page 15 of the manual at
Aug 18, 2011 | GE 21008GE2 Dual-Handset Cordless...
Ge 27831 Cordless dual phone 2nd handset doesn't work
Another user (thank yoiu but I'm sorry I forgot his/her name) had the answer. It was ihe instructions but I missed it. Needed to set the 2nd handset into the main base for 20 seconds so that it could align itself.
Mar 21, 2009 | GE 27831 Cordless Phone
GE Cordless 25952EE1 A Cordless wont register in base base flashing CL
After talking with Thomson Inc today your best bet is to get rid of the phone. I found out today this phone has a real problem as I see it. I can use my handset on other bases. So that means anyone with this model handset can access your line. Thomson agreed today that this is possible. All I got was a SORRY!
Mar 09, 2009 | GE 25952EE1 Cordless Phone
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
I have GE 5.8 GHz model 28021EE2-A with no user guide
If you don't have users guide then just bech maro that product........
Jan 25, 2009 | Uniden Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
GE DECT 6.0 Model 28111EE2 is not working, registration failed message
I had the same problem, and restoring to default settings did not seem to work either. I just opened the back, unplugged the battery, plugged it back in, and now it works again.
Aug 26, 2008 | Uniden Cordless Phone
Handset needs registration
I had the same problem and have seemed to figure it out. Take the handset near the base. Press the Prog/Mute button at the bottom of the phone. It will display a message to press the Pager on the base. The phone will then ask you for a Handset Name. Press the Prog/Mute button again and it will name the handset Handset 1.. it is working
Jul 31, 2008 | Uniden Cordless Phone
Cordless GE phone issue. 25825GE3-A
1. press the "talk" button FIRST
2. then press "program" button and follow instructions on screen
only one phone said "needs registration" but had to register all 4 phones but this worked for me
hope this helps
Sep 11, 2007 | Uniden Cordless Phone
GE 25952 5.8 GHz
I just called GE/Thomson tech support (1-800-720-2094). GE cordless phones do not allow users to pick up an additional extension so that two people in the house can speak with a caller. He explained that it was for privacy.
I will be taking back my system today. :(
Aug 20, 2007 | GE 25952 Cordless Phone
GE 28021EE2 Phone Logo
50 people viewed this question
Top GE Phones Experts
Are you a GE Phone Expert? Answer questions, earn points and help others
