Question about Motorola Mobility W315 Cellular Phone
Text ringtones i can't apply my text ringtone to my ringers
Ok my phone wount work right if i push 1 button it gose crazy wount let me send text i dunna no whats wrong with it is there some how to reset the whole phone!!!! HELP
Posted on Oct 02, 2008
SOURCE:
Tracfone customer service
  1. Check a ringer volume and profile. Press a volume key to see the volume status bar at the top of the screen. Use the volume up and volume down keys to adjust the loudness of the ringer (scale 0 to 30). Tap on the text next to the ringer icon to change the profile (vibrate only, ring+vibrate).
  2. Check if the issue is with a specific ringtone: Go to Settings > ringtones+sounds > Ringtone, and tap on a playbutton to preview the ringtone.
  3. Switch off the ringer vibration (Settings > ringtones+sound > vibrate) temporary, to determine if your phone is affected by any motion settings i.e. Flip-to-Silence.
  4. Make sure that call forwarding is not switched on: Tap the phone icon > ... > Settings.
If the problem persists, restart your phone by pressing and holding the power and volume down keys simultaneously until the phone vibrates. Release and the phone will restart. After this operation, you may need to re-adjust the volume and set date+time on the phone. Note that this does not remove your personal content.
Mar 13, 2014 | Computers & Internet
How can i make a song a ringtone on my rokr e8? i used to be able to on my old phone... Now apply as.. ringtone is grey and nothing happens when i click. Also how do I get the thing that reads out texts...
for the ringer you need to download it to you sd card and move it to the phone memory and after that go to your ringtones select the one that you moved to the phone and that should work for you properly and for the messages you need to reprogram your phone by press 74663# hit manu twice and you have to be fast on pressing the clr button twice for you to go to programming so its
74663# clr clr fast ok
good luck from rymi1982
Jun 17, 2010 | Motorola Mobility ROKR E8 Cellular Phone
How do i change ringtones ive saved on my phone
1st go in settings then in ringer alert style and edit then go in ringtone line 1 and then change your ringtone for motorola e6
Jun 01, 2009 | Motorola Mobility ROKR E6 Smartphone
Can't set ringtones that are in my memory card as ringtones!
well if u have internet on your phone you could try buying ONE ringtone and one that ringtone is installed a new folder will come into existance. i think its caled my contestant of something. Anyways, try connecting ure phone to your pc and from then on, all songs u downlaod should become a ringtone if put into that folder. Just a guess though. try it
Mar 29, 2009 | LG RUMOR Cellular Phone
hello dear
to resolve your problem
Tap on setup then
Tap on ringer alert style then tap on edit then
below ringtone 1 then
scroll down n tap on more then
tap on the memory card
then browse the ringtone from ur location u have saved ur ringtone earlier
have nice time
Shookkee
May 15, 2008 | Motorola Mobility ROKR E6 Smartphone
Purchased ringtone- text messages
Go to your contacts menu-selet it, find the person you are wanting this specific ringtone for- select it, go to options- select it, go to edit- select it, then go to ringer-this should be where you edit there ringtone, add a picture, etc... hope this helped.
Apr 14, 2008 | Motorola Mobility RAZR V3
Ringer ID
Check the settings that allow you to assign ringtones to numbers and their should be a assign to text setting, just change it to not assignt to the text.
Hope that helps.
Dec 26, 2007 | Motorola Mobility RAZR V3
Ringtones
Go into ring styles, and see if you can't select the ringer from there.
settings>ring styles> detail > calls, and hit change/select
Oct 02, 2007 | Motorola Mobility RAZR V3
Ringtones
hi, before applying tone, play it & listen, if it plays sound. Resent ur mobiles master setting & apply now. bye
Oct 01, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Ringer id
If you have an SD card it might be stored there. You might have to copy or move it to the phone storage from trans T-flash.
May 03, 2007 | Motorola Mobility RAZR V3
Motorola Mobility W315 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
