Dyson service engineer has confrimed that the main bearing is badly worn but replacement bearings and/or drums are no longer available. What are my options?
its all down to the water seal in the bearing housing if this is gone the machine is scrap as you can not get them.. The bearings can be got from any good auto (car) bearing supplyers.they need to patten mach them for size.this is the main steel bearing that the hole drum spins on there is also a small brass bearing thats part of the two way drive system but this needs a puller to get to it..bottem line is if the drum does not turn both ways in side its scrap..if you take the back off and theres rusty/gressey water dripping off the back off the drum..scrap it
you can try this site You will need more information they are after market but will have it in stock or have a locter service to see if they can find one. Thanks for using Fix-ya If this was helpful please rate http://www.appliancepartspros.com/
Avid101
dyson cr01 showing fault 70 600 2701 when i clear it by following the hold temp while turning on and...
(More)
dyson cr01 showing fault 70 600 2701 when i clear it by following the hold temp while turning on and pressing soil within 3 seconds i get the next fault showing f11f10f11v130
my dyson cro1 is saying not filling but there is water in the drum then the washer stops it seems to...
(More)
my dyson cro1 is saying not filling but there is water in the drum then the washer stops it seems to fill on the left side of the powder draw please help me
