Question about Dell PowerEdge 2600 Server
PowerEdge 2600 does not boot up ?
I had brought an old PowerEdge 2600 server from someone.
It seems they had formatted all the scsi hot swap drives .
Server does boot up into the BIOS and it shows cdrom as first boot seq.
I have the DELL system management/diagnostics cd and when I put the cd's
in the server it does not boot to the cdrom .
Any help
  • 1 more comment
  • t1993r Dec 30, 2007
    Already enabled the CD-ROM device in the Boot Sequence list of the System Setup. But still, PowerEdge 2600 still says "No boot device available.". I'm trying to boot with the Dell Server Assistant CD as well as different Linux Distros. I've tried to boot the Linux Distros in a different box and it boots well, but not on the PowerEdge 2600 server. =(
    Any help is highly appreciated.
  • Anonymous Oct 30, 2008
    My PowerEdge 2600 does not boot up from CD-ROM, i've tried the WIndows Server 2003 CD, the Instalation and Server Management CD, the OpenManagement Server Assistant CD and other OS bootable CDs. The PE2600 aways says: "No boot device available".
    The CD-ROM is listed as the first device on the boot sequence.
  • Q4SteveB Nov 28, 2008
    Chances are the CD is 'broken' (or otherwise non-bootable) ..
    I spend hours downloading ISO images from the Dell site, however their titles are confusing and I never did find the 'right' one ..
    Just top confirm it wasn't the CD drive I used an XP Pro CD .. this 'booted' and started an install sequence just fine (but of course failed when it came to look for the hard disk ..)
    I then resorted to floppy boot set - however the PERC Raid drivers on Dell's site do not work with installation floppies (it seems you have to use the install CD shipped with the product to 'make' a floppy installable driver ... which (of course) you can only use after install ...)
    Eventually I gave up on trying to install an OS onto the RAID system ... my solution was to fit a SATA card (about £10 off eBay) and use that to support a bootable drive .. (I removed the useless Tape drive and used the space for a pair of SATA drives configured as 'Mirror')
    Once you succeed in loading an OS you can load the Dell RAID drivers and all works just fine ..
This server is a compleate wast of time trust me
Posted on Jan 18, 2008
    Scholar:
  • 58 Answers
You need to set the boot device order. Usually F12.
or you can go to bios with F2 or F10.
your cd-rom is wrong you need the Instalation and Server Management CD. I think it's possible to download this cd at their site.
good luck
Posted on Dec 07, 2007
SOURCE:
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
Maxtor SCSI 36GB hard disk drive was removed from
if you are using raid go into the perc hardware utlity as it boots,try formating the drive there.maybe this will work.If you are using the dell open manage software you can probably format it there in windows.If you are not using raid enter the scsi utlity and do a format there.
Good luck
Sep 09, 2009 | Maxtor Atlas 10K III 73.4 GB SCSI Ultra320...
Drive Options with a Dell Poweredge 2600
I would definitively not recommend to remove the backplates, unless you want to ask for serious trouble with your system.
I would install a PCI SATA adapter card (one like these) and connect your SATA drives to it.
May 27, 2009 | Dell PowerEdge 2600 Server
I'm having some trouble with a dell poweredge 2650 I bought off eBay.
You are not too clear, however I'll take a guess ..
1) Booting from CD ... older CD drives fitted to PE26xx range do not recognize Windows 2003 bootable install CD's .. the TS-L462C (a laptop drive) should be compatible with the PE 2650 (I know it works in my 2600)
2) Installing the Operating System onto the PERC SCSI Array drives .. a total pain .. with older OS (Windows 2000) you can use the 4 x floppy disk set to install and hit (F6 ? as I recall) to tell it to 'load a 3rd party driver' ... get the PERC drivers from the Dell site.
Alternative = toss the useless Tape Drive and install a set of SATA drives in the same space (a 3 drive Hot Swap caddy eclosure will fit = Icy Box or StarTech) .. you will need a PCI RAID card (such as Si3124) since the M'Bd has nothing but a combined floppy/TapeDrive IDE interfafce.
3) Finally, be aware that this is a SERVER level box .. spare parts & Dell 'official' upgrades are going to cost you an arm & a leg = and don't even ask what the special 'ECC parity' Memory sticks cost :-)
Jan 22, 2009 | Dell PowerEdge 2650 (PE2650BB) Server
I need to add more hard drives to my poweredge 2600
You'll probably need to get caddies for the drives. You can get them from Dell by plugging in your service tag at http://support.dell.com.
Jan 12, 2009 | Dell PowerEdge 2600 Server
Replacing bad hard drive
Can you explain more about what you are trying to do?
Is this a RAID configuration?
Is it SCSI or SAS or something else?
Thanks!
-Chip
Nov 04, 2008 | Dell PowerEdge 2600 Server
New HD in PowerEdge 2600
Put the hard disk in, allow the OS to identify it, format the drive and you'll be all set.
Jul 19, 2008 | Dell PowerEdge 2600 Server
I want to format scsi drives and configure raid0
You can either do this in the BIOS or (easier) just run a Linux installer (such as Ubuntu) and it will offer to do it for you when it sees Windows-formatted partitions.
Jan 06, 2008 | Dell PowerEdge 2600 Server
Poweredge 2600
A larger drive should auto-configure just fine keep in mind that you may not get access to the full drive depending on how you have it all setup. In any case if there are any problems with the auto-configure you should be able to easily go into the RAID manager and tell it what you want to do with the drive.
Nov 12, 2007 | Dell G6632 146 GB SCSI Ultra320 Hard Drive
Dell PowerEdge 2600 Server Logo
3,906 people viewed this question
Ekse
Clive
Clive
