My personal computer has recently developed a problem with its power on/off behavior. When I turn on the external power source (i.e. plug the power cable into wall outlet and turn the switch on) some components inside the computer turn on which is unusual. The power indicator led on board, the power indicator led on chasis, the PSU fan, the heat sink fan and the harddrive all come to life without having me to puch the power button on chasis. However, the system does not POST and no display appears on screen until i push the power switch on chasis.
Similarly, the computer does not shutdown as expected. When I shut it down via windows shutdown command, it ''tries'' to shutdown but at the moment the computer ''supposedly'' shuts down, the leds, fans and hard drive is still operating (it normally makes very faint sound when its spinning which i can still hear).
The motherboard is ASUS A8V-VM SE motherboard and the problem is either mobo or power supply related. It is probably not a faulty-power-switch-on-chasis; i tried disconnecting it from mobo and then turned on external power and again it turned on in the above mentioned state.
Any ideas about how to set it back to normal -- ie. the pc should not turn on until i push the power button on the chasis?
Comments:
Aug 21, 2009
- The computer is working. It works when i turn it on. I am writing this comment from the computer in question. The problem is that some parts start operating when they should not.
If all the parts of your computers are fined functioning. This is a CPU problem witch is no display. Try to disassemble the CPU remove the heat sink the CPU and clean and insert it again. When you are now inserting the CPU be sure that you will put a thermal past in the heat sink so that the heat from the CPU are absorbed. If the heat will not be absorbed it will cause overheating.
i have acer make veriton 7500G model CPU . i have lost my mother board driver CD .the motherboard...
(More)
i have acer make veriton 7500G model CPU . i have lost my mother board driver CD .the motherboard model is acer s88m model .after formatting i required this so please send me this driver cd if you have... ........
ms-6577 v2.1 motherboard need location of pwsw and reset sw from atx case to board ms-6577 v2.1 this...
(More)
ms-6577 v2.1 motherboard need location of pwsw and reset sw from atx case to board ms-6577 v2.1 this case came with 4 fans plus pw sply. is this too much for this bd . I smell alittle toasty but it all turns on ok if i connect a fith to the middle. not the cpu fan . ihave a 500 watt pw sply.i want to make sure the wires are connected right and that what i smell is just too much so i can disconnect and just get me a newer bd with instructions...thanks. if icould view a pit .would be great..
Will new micro atx boards fit inside of a hp pavilion 4550z case? I am trying to overhaul my old hp...
(More)
Will new micro atx boards fit inside of a hp pavilion 4550z case? I am trying to overhaul my old hp pavilion 4550z with a new os and new motherboard as well as processor. My problem is I am not sure that the micro atx motherboard I plan to get will fit properly in the old hp pavilion 4550z case.
Planned new motherboard: GA-M61PME-S2P
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
