Question about Amana ALW880WH Top Load Washer
Washer stopped after filling, small load
I put in a small load, and turned washer on. After it filled up, it just stopped. It never made any noise or anything. I have checked the breakers and changed to another outlet, but nothing. It is not off balance either. I have messed with the knobbs and finally left it to sit. I have been doing laundry all day, did this do something? Any advice?
  • jhapka Oct 13, 2008
    My machine fills (large, small, or medium load) and then won't start washing. It sounds like the motor is trying to do something and then it just clicks off. If I wait about a minute and then turn the knob to the rinse cycle, it will spin and the water will drain out. If I have the washer fill up again, it repeats itself and won't start agitating??? What's Wrong?
    Please advise.
    Thanks!!!
    Jim
  • Anonymous Jan 01, 2009
    I have a Kenmore top loading washer and I put a medium load of clothes in and it filled with water, then stopped. I have checked the breakers and everything seems to be in good order. Help!
  • 246 Answers
I would check and make sure the lid is not bent or bowed. If the middle part of the lid is too far down when closed, the machine thinks it's open and wont run an agitate or spin. If it is bent, just bend it back for a quick fix.
Posted on Jun 16, 2008
MY whirlpool WASHER MACHINE FILLS WITH WATER BUT DOES NOT WORK AFTER THAT. IT DOES MAKE SMALL NOISE LIKE MOTOR BUT DOES NOT WORK.
Maytag LAT3600A Top Load Washer
1 Points
Nov 27, 2012 | Maytag LAT3600A Top Load Washer
Won't fill
Try putting the clothes in and filling it with a bucket via the top opening (Cold water will do)
If it starts and washes then it is the fill valve which has gone faulty , if you put in the normal fill level and then exceed by say another bucket full, that indicates it is the pressure switch.
Ps
You might try taking the fill hose off the back of the amchine and clean out the small filter which is just inside the opening
Jan 24, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Fills up with water and shuts off...
This information may help you to learn more about your washer.
copy n paste
http://www.partselect.com/MultiModels.aspx?ModelNum=RAS6233KQ&searchTerm=img_I3TR96FR&RefineSearch=0&imgMfg=Whirlpool
becouse it was over load it may be out of balance becouse of the
exessive weigh.
"Did it solve your problem?"
Apr 01, 2009 | Roper RAS6233KQ Top Load Washer
Water will not stop filling tub.
the problem is that your pressure switch is not working properly. if you take the screws out of the back of the head you will find the pressure switch. first unplug the washer then undo the hose from pressure switch. blow trew the hose, then blow into the pressure switch if you hear the pressure switch click then re assemble and try again put on small load and watch if fills almost to the top or over flows replace pressure switch
Feb 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Dec 12, 2008 | Maytag HAV3460AWW Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Oct 10, 2008 | Whirlpool LSR7333 Top Load Washer
Amana ALW880WH Top Load Washer Logo
75 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
