Question about LG C1500 Cellular Phone
LG C1500 phone is stuck on headset mode and no headset is in it. How do I get the phone to turn off this mode?
  • 1 more comment
  • exit98 May 29, 2008
    my lg chocolate phone is stuck on headset as well.  i can receive calls but cannot hear anything on the other end of the line nor can the other caller hear me.  how do i turn off headset mode?
  • TTjj Jul 09, 2008
    my Audiovox 8615 is stuck on headset mode and there is no headset in it. When I place a headset in it, I can hear but cannot be heard by caller
  • Anonymous Mar 05, 2009
    my lg rhythm is stuck on it and have no headset in it
PERSISTANCE IS KEY!
My Palm Centro sat in a small puddle for a few seconds, and the only thing that was wrong was that it was, like every other poster here: Stuck in Headset mode. For 3 days I read posts / forums all over the place, getting similar ideas about inserting/pulling out the speaker cord rapidly / soft or hard resetting / pulling out at a certain point etc etc.
The real problem was that inside the 2.5mm jack there is a little microswitch that enables / disables the headset function, and if it gets stuck open- nothing can override it. --- Again --- 3 full days of twisting, pulling out, screwing with the jack and wasn't able to get anything out of it- was about to say screw it.
THE ANSWER!!! -- I read somewhere that using a Qtip could increase my chances of snagging the switch down; I doubled my odds and sprayed the **** out of it with WD-40 (with the fore-idea that the switch got all gunked up and is stuck in the open position)
--To test it out, start playing a music file or anything that should originally go through the main speaker (or just call your Voicemail)
-- I got the tip wet with the wd-40, and since I have a 2.5mm jackport (not even the qtip stick fits in the hole) I started twisting the cotton off of the stick into an elongated portion of the wet cotton; long enough to fit in the port. I stuck it in (twisting in the same fashion as the twisted cotton) and just started twisting. About a minute worth then I yanked out and-- WaLaa! MUSIC
Only thing that worked in 3 days; I figure the individual cotton strands snagged on the thing and pulled it down, although I contribute it finally moving to the WD-40.
GOOD LUCK =)
Posted on Apr 05, 2009
My gf had the same issue with her LG265. all we did was stick a toothpick in it and apply slight pressure downward while pulling out in a raking motion. it came unstuck immediately. Hope this helps!
Posted on Jun 06, 2011
  • gillzilla85 Jun 06, 2011
    just stick a toothpick in it and apply pressure down and pull out in a raking motion to unstick the mechanism that tells the phone whether a headset is in our out. dropping a phone can sometimes jar this loose. Hope this helps!
Lg shine stuck on headset mode
Try connecting your headset again and then disconnect it after a few seconds. I think there's just an issue on the headset outlet.
Hope this helps! -jayps
Mar 16, 2011 | LG Shine KE970 Cellular Phone
My lg ryhthm phone got wet and now its stuck in headset mode
Your phone's headphone jack port is shorting. Try turning the phone off then dry it with a hair dryer for 5 minutes. Turn it back on and see if it helps, if it doesn't well you now have a permanent damage on your phone, its probably the headphone port controller, its busted...
Jul 14, 2010 | LG C1500 Cellular Phone
My phone is stuck on headset
I would try a to reset by pulling the battery out then putting it back in.Leave it out for about 30 seconds.
Apr 18, 2010 | LG C1500 Cellular Phone
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
My LG Voyager stuck on headset mode
Turn your phone off and remove the battery. Also tap the headset port (where a headset would normally plug into).
When you reboot it back up it should fix itself. If it doesn't you have a hardware problem (its physically broken) you can see if its under its 1 yr warranty to get your free replacement, or if its older - there's always cell phone insurance.
Oct 28, 2009 | LG VOYAGER VX10000 Cellular Phone
LG shine stuck on headset mode
reset the phone or cntuck to lg care
Apr 10, 2009 | LG Shine KE970 Cellular Phone
My lg u8330 is stuck in headset mode and wont turn off
Dear,
turn off ur phone by removing battery and turn it on again and then change the mode of it.
regards,
dont forget to rate it as it will fix the issue
Feb 21, 2009 | Cell Phones
HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 21, 2008 | Motorola Mobility HS850 Consumer Headset
Purple light
The purple (majenta) light usually means it is in pairing mode. Is it possible that the button is stuck pressed in??
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Jun 09, 2008 | Motorola Mobility H700 Wireless Headset
My lg hbm-730 headset is stuck in pairing mode
I have the exact same problem. I suggest you flush the LG piece of **** down the toilet, and never purchase from LG or bluetooth again.
Sep 09, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG C1500 Cellular Phone Logo
5,661 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
