Question about Dell 924 All-in-One InkJet Printer
Carrier Jam We tried everything that other customers had suggested but nothing worked. We dont see 3 plastic strips, only one in the rear of the carrier so where are the other two, can you please help us fix this problem. Thank you!
    Genius:
  • 1,003 Answers
Lubricate carrier bar with two to three drops of 3in 1oil on top of bar with power off then power on to check operation
Posted on Jan 07, 2008
Carrier Jam, there's nothing in it, I put new cartridge in still saids carrier jam, other then that this thin strip came out
The thin strip could be the encoder strip (transparent strip) which is responsible for the proper movement of the cartridge carrier along the carrier assembly. Please contact Lexmark Technical Support Center for additional assistance.
Sep 21, 2011 | Lexmark X4650 InkJet Printer
Carrier Jam
This is what my printer did when it kicked of the 14" plastic strip inside the printer(see posts referring to strip). Look inside for a loose, quarter inch wide and 14" long plastic strip with slots on the end. Let me know if you solve this.
Dec 15, 2008 | Dell 926 All-In-One InkJet Printer
Carrier jam on printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Clear carrier jam
In your case It seems like the Encoder strip is broken or its out of printer . However if you see encoder strip inside the printer connected from left to right, try these steps.
Solution:
1. Cleaning the encoder strip:
2. Repositioning the Encoder strip.
Oct 26, 2008 | Dell 924 All-in-One InkJet Printer
Dell phto 924 clear the carrier jam
Solution:
Oct 10, 2008 | Dell 924 All-in-One InkJet Printer
Paper Jam wont clear and there is no paper in it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Reposition the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Ensure the Paper Tray is Not Overfilled
Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray.
Aug 17, 2008 | Dell 924 All-in-One InkJet Printer
Dell 922 printer jam
Note:
Reseat the Dell Printer Power Adapter.
If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
Check with manufacturer if printer is still covered under warranty...
If yes then get it replaced.....or else get a new printer
Jul 31, 2008 | Dell 922 All-In-One InkJet Printer
Carrier Jam
THis solution I copied from another post. It worked for me as well
First you need to open the printer. Unplug from power. Then lift the scanning device, you can partially remove it when pushing the "hooks" close to where the lid is connected (careful with the cable connections). Then remove three screws in the cover of the bottom part and with some fiddling around you can remove the cover. Again be careful with the cable connections. Of course don't do it if you are worried about warranty or breaking the printer.
The plastic strip has slits at each side to attach to the inside back of printer, on the left side is a down ward facing arrow, the plastic strip feeds through the back middle of the cartridge carrier and then the slits are to be inserted to the metal tab like pieces on the back sides inside the printer on the right side (facing printer) it will look like a small rectangular hole with a longer metal tab like piece sticking out & on the left is a smaller squared like hole with a flat smaller metal like tab which will line up if the plastic strip is feed through the back of the cartridge carrier properly. This should allow the cartridge carrier to glide properly & work as it should, with no more banging.
Success
Jul 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
Carrier jam
Do have a slamming noise.Then the encoder must be broken or it may displaced ..if its broken your printer is defective...
if out of place u can fix it Note:::::::::encoder strip is very delicate in process of trouble shooting it may get damaged so take extreme care please use this link to trouble shoot:::::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS22722&relevance=0
Mar 16, 2008 | Lexmark X5470 All-In-One InkJet Printer
Carrier Jam
I loaded to new cartridges into the printer1.gif, switched it on, cartrigde went from one side to the other with a bang, error on printer reads, clear the carrier jam, cn you help?
ed
Jan 11, 2008 | Lexmark OfficeCenter X3350 All-in-One...
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
