Sony KP-EF41SN2 rear projection
Hi, set came in dead. Found lopt and output transistor faulty. Replaced and started up fine, ran for an hour and has blown the output transistor (2sd 2539). Any assistance is appreciated. Thanks.
Hey i have an sony kp-ef41sn2 and i can not get the green convergene to work the v side woks but not the h siide can someone plese help
Posted on Feb 28, 2008
  • stumps666 Feb 28, 2008
    hello i have a sony kp-ef41sn2 con someone send me the manual or the convergence nubers that will be grate thanks
Sony kp-51ws500 will not come on
Next to FBT flyback transfomer near the Hori output transistor is a high voltage capacitor 2k v check it it feeds to the output transistor and if it is bad high voltage will not come up.
Oct 15, 2011 | Sony KP-51WS500 51" Rear Projection...
4 blinks on the on/off switch. Vertical output or buffer? How do I fix it. Do i need to order a part? thanks
Most of this error code, vertical output IC(IC1509) is the caused of the symptoms. You have to test also the vertical pulse buffer transistor (Q1505) if faulty using the multimeter.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 08, 2011 | Sony KP-43T90 43" Rear Projection...
Hi,im a technician and i got a problem with a Sony Trinitron Colour television model Kv-T29mn3. I replaced an Str, capacitors & Horizontal Output Transistor. Voltage output its okay but it keeps on...
These sets had alot of problems with bad FBT flyback tranfomers,You might need to change FBT.
Heres another thing they also had Bad Picture Tubes that will blow hori output and you will not know its the Tube untill you replace the FBT.Use a high voltage probe to monitor Voltage coming from the anode button, if you dont have a HVP then disconnect the CRT board and monitor set.
Jun 26, 2011 | Sony KP-57HW40 57" Rear Projection...
Hi my Sony kp51ws510 is stop no picture no sound it look like something to do with power supply problem can someone tell me what to do thank you
FBT flyback Transfomer, CK Hori output Transistor and small blue Capacitor that Feed to Hori Transistor,Cap is 2Kv
Acme Has good Deals on FBT 1-800-575-9833
Oct 05, 2010 | Sony KP-51WS510 51" Rear Projection...
Hi i have a sony kp-41ds1u rear projection which has lost picture and audio but the power light flashes on when pressed ? can it be fixed ?. It was turned on one morning but made a small pop sound and lost...
On your powerBoard the one that has your FBT flyback Transfomer
Look at the hori output Transistor and right behind it feeding to output is a 2K volt capacitor Ive seen them with tiny burt hole in them,causing lost of high voltage,if it is OK then you either have Bad FBT or Bad STK ICs. STK392-110s Mats Has Parts for this set 1-800-628-1118
Aug 22, 2010 | Sony KP-41DS1 41" Rear Projection...
Flashing screen
% blinks for your model means a video output abnormality. which translates into IC7101, IC7201 or IC7301 on C board circuit is faulty or else its transistors Q510, Q516 or Q524 are faulty on the A board. I would check the transistors first for being faulty and if they check out then suspect one of the ICs
May 12, 2008 | Sony KP-53XBR300 53" Rear Projection...
Sony kp46wt510 with 6 blinks can anyone help
• +5 line is overloaded. (A, B Boards)
• +5 line is shorted. (A, B Boards)
turn off for about about 4 hours
Feb 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Bulbs - Sony KP EF41SN2
Well, those are really called CRT tubes and are way more expensive than your average bulb. I would not recommend fiixing a 7 or 8 year old (is that right?) projection TV with bad CRTs
Jan 08, 2008 | Televison & Video
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
