Question about Epson Stylus CX3200 All-In-One InkJet Printer
MYH EPSON CX3200 IS READING ERROR SCANER ERROR --SEE YOUR DOCUMENTATION AND CALL SERVICE IF NECESARY
CAN YOU HELP ME TO CORRECT THIS PROBLEM.
Install on your computer and run the utility, when it asks if you have replaced the waste pads click on yes. If the printer resets and a steady green light is on, now is the time to replace the pads.
You will have to remove the scanner unit from the top.
Undo the four retaining screws from the casing under the scanner unit and remove the printers outer casing. you can then see the waste pads. Remove the pads (the good bit,be careful ink can go every where) in the past I have washed them out under the tap and left them to dry and then replaced them, all has been ok.
Posted on Jan 07, 2008
Try making sure the scanner lock on the left hand side of the scanner surface is set to the unlock position. If it is set to the lock position, you will get an error.
Posted on Dec 15, 2007
Printer error see your documentation and call service if ....
i have epson stylus cx3200 error see your documentation and call service
Oct 01, 2012 | Epson Stylus CX3200 All-In-One InkJet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson cx3200 error light is on and screen reads "printing error consult documentation if neccessary contact service" have tried reseting the protection counter but doesnt seem to work any ideas?
look for anything jamming the print head, then try lubricating the bar the print head runs on. power off then gently move the head left to right so spread the oil. hope this helps
Apr 02, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 Error
Possible scanner failure.
Turn off your printer. Disconnect it from your computer. Toggle the transportation lock on the scanner unit if there is any. It has to be in the unlock position. Turn the printer back on.
If your unit is not yet a year old, please contact epson for your warranty options.
To help you find an epson certified servicer near to your area, please log on to epson.com.
Apr 28, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson cx3200
If it can print from the printers stand alone function....
1.) check on cable connections > transfer usb cable to a diff usb port > use a diff usb cable
2.) check on printer driver >
cancel pending documents > Control Panel / Printer and Fax ( for windows systems )
Whats the OS on your Computer?
Mar 20, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
SSC Service Utility v4.30/ Epson CX3200/ "See documentation" error
Please go to my website http://www.the-inkstore.co.uk where I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Everything you need to know will be there. For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson CX3200 printer error
i just fixed the problem .. you have to reset the protection counter FIRST .. then do the reset using the triangle and colour buttons.. this it the link for the SSC utiliity to reset the counter www.ssclg.com/epsone.shtml .. my printer works fine again
Oct 18, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
101 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
