Question about Umax AlphaVista Flatbed Scanner
Ups not getting charged
I have a supercom ups which is not getting charged. it is shutting down immediately after the power cut. what should i do now.pls suggest me some solution.
thank u.
    Scholar:
  • 112 Answers
If you have access to a volt meter you can power down and check the voltage and see if it is as high as the battery says. For example the side of the battery says 12 volts..you read 10 volts or less let the battery charge for 24 hours and test again if it is still 10 volts (while not pluged in) one cell in the battery is bad and the battery needs replaceing. If you watch the connections you could change the battery yourself for less than a third of a new unit. The units rearly go bad but the batteries have a shelf life whether used or not.
Posted on Aug 21, 2009
SOURCE:
Car shutting off
whilst i am not familiar with the actual car i would say...
if it cuts out immediately then its electrical...check coil, ignition amplifier etc.
If the car cuts slowly by losing power, spluttering etc it will be fuel related....fuel pump, fuel pump relay, fuel filter.
Does the car restart immediately or do you have to leave it for a while?
what happens just prior to the vehicle shutting down?
Roger
May 10, 2014 | 1996 Mercury Grand Marquis
99 dodge durango
Could be a problem in the ignition circuit. Check or test coil and ignition module-one of them may be shutting down or shorting out when they get hot.
Verify by checking for spark at a plug wire immediately after it shuts off: if no spark, it is an ignition problem. Besides the coil and ignition module, other possibilities are the crank position sensor, cam position sensor, ecu, the ASD relay (automatic shuit down relay-it's in the power distribution box under hood). If that relay fails, all power is cut to coil and fuel injectors, and maybe the fuel pump also.
Good luck.
Dec 20, 2012 | 1994 Oldsmobile 88
Purchased a new Dell Inspiron 6000 (9 cell) battery
You just want to refresh battery from the BIOS. There problem will be solve
Mar 15, 2010 | Dell Inspiron 6000 Notebook
Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Mar 06, 2010 | Kodak EasyShare V1073 Digital Camera
Steam Shower shuts down immediately now.
probably scale build up from tap water unfiltered. Scale caused by mineral deposits will affect safety systems and auto cut offs in the unit
Sep 13, 2009 | Mr Steam Mr. Steam Commercial Steambath...
Phone powers up and immediately shuts down
Normally it is battery problem. First check your batter by charging fully. If your battery is ok but same problem then you need to reflash the phone, I mean reprogram the phone.
May 18, 2008 | Samsung SGH-X700 Cellular Phone
Battery appears charged, but computer will only run when plugged in
does your battery have one of those charge indicator panels on bottom?
also, it's possible that the connection from battery to the internals is shot..if that's the case, then you're looking at a major motherboard swap
May 15, 2008 | Lenovo 3000 V100 Notebook
Archos 504 Powers Up and Immediately Shuts Down!
bad battery bad ones will show charged but cant push out full violts pc needs ok buy new one 1st
Jan 28, 2008 | Archos 504 500870 Digital Media Player
Shutting down
Does it cut out on battery?
How often does it cut off?
Does it just die (no lights or anything) or reboot?
Jan 14, 2008 | Toshiba (K000006610) for Satellite P25...
Open Questions:
See all Umax AlphaVista Flatbed Scanner Questions
Umax AlphaVista Flatbed Scanner Logo
135 people viewed this question
Top Umax Office Equipment & Supplies Experts
Thomas F. Schneider
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
