Question about Garmin StreetPilot c550 GPS Receiver
Feedback problem the device will give off high pitch sounds when traveling after about 15 minutes of traveling. very lound sounds device is not really useable with this problem please send me an email at davidhill00@yahoo.com Thank you!
  • gordonshere Dec 03, 2007
    I have a garmin c550 and it is giving off alot of feedback lots of high pitch sound please help
Gordonshere
Is there a spot you can install the Garmin that will reduce the heat build up within it? I've noted some audio issues (however not a loud high pitched sound) when my Garmin gets too warm from direct sunlight baking it (along with it's own internal heat build-up) I get a crackly, nasty sounding voice that goes away if I cool the unit down. I've since put mine on a stalk between the front seats out of direct sunlight, heater outlets and away from other audio output devices (heat and RF sources) and have eliminated any audio break down. Before I isolated the unit, allowing it to stay as cool as it could, I also noted that when one of my units gets very warm it would also drop satellite connection. Because of the delay you're experiencing (15 minutes) it sounds like a heat build up issue for you as well.
Posted on Jan 06, 2008
High pitch sound
this sounds like the microphone is picking up feedback, if you are not using the mic then go to control panel then sound and disable the microphone
Apr 19, 2014 | Acer Aspire 5735-6694 Notebook
91 sonoma wont turn over just wines
A whinning noise is usually from the starter spinning but not engaging with the flywheel.
The solenoid or bendix gear may not be working which would require a replacement starter.
If you heard a grinding noise, I would say some teeth are missing from the flywheel.
Feb 08, 2013 | 1991 GMC Sonoma
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I get a high pitched noise when in pro tools
I don't know what devices are connected to your audio input ports, sounds like gain is too high on a microphone or guitar or speaker setting too close to your work station, sound like feedback loop.
Nov 02, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
Squeaking tv
If you have an AM radio/ other electronic device that is not well shielded close to some TV systems, it can also cause this type of sound in Stereos, turntables, computers etc... a lot of the time it is really easy to track down.
OR
You have a bad electrical ground in your apartment/House that needs to be checked quickly. Feedback is rarely a good thing!
P.S. you should always have your electronics all running off of the same ground via a surge protector of some type.
Hope this helps
Sep 18, 2009 | RCA R52WH73 Projection Television
MY HOME THEATRE AMP. SHUTS OFF ITSELF, AND SOMETIMES SCREAMS W/ N
First suggestion is to recheck all the connections
Rifaa
Nov 12, 2008 | GE GTD120 System
Alesis M1-Active left speaker emitts a very high pitched wine that sounds like feedback
have your built-in amp checked for trouble. there should be trouble in the output stage feedback loop. this is something to be done by a repair technician
Apr 11, 2008 | Alesis M1-Active MkII Main / Stereo...
Awful High-pitched Noise and Echo Feedback
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Jan 17, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
HIGH PITCH ON VOICES
This is possibly a sound card issue. Your card may itself may need updated drivers. Go into device manager and find your sound card and see if they have any updated drivers from there website. If you happen to have another sound card throw it in and see if it does the same thing. Last but not least is these speakers will work with a MP3 or other device, plug into them and see how it sounds, if your having the same problem with lets say a cd player or mp3 then the speaker itself is faulty.
Sep 15, 2007 | Logitech X-230 Computer Speakers
Garmin StreetPilot c550 GPS Receiver Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
