Question about Sony PlayStation 2 (PS2) Console
PS2 screen won't show on tv set to game
I plug in the ac adapter into the wall and the 3 colored prongs into the tv's slot for the audio/video in the correct order. i turn on the ps2 and nothing happens. i hit the reset button and the fan turns on but on the tv won't show anything, just black. i need to know how to fix it please.
  • Anonymous Dec 08, 2007
    i turn on my ps2 and i only get a black screen
    Champion:
  • 209 Answers
Try to trouble shoot if the wire is the problem, how? remove the 3 colored wires from the tv and ps2 then try to use the red color instead of yellow to the video from tv and ps2 (both red) temporarily do not use the yellow color. once a picture appears use now the white for the audio (both white) for left audio once there is a sound you may try the yellow for the right audio. i hope this will help you and hear a positve reply from you.
Posted on Dec 03, 2007
SOURCE:
When i turn on my ps2(slim) i cant see or hear eny on the TV way is the happing plz help me
Check your A/V cable connections. They are the Yellow (Video), White (Left audio), and Red (Right audio)wires coming from the back of your PS2 to the connectors on your TV. Be sure they are plugged in and they have a tight connection. Also, be sure they are plugged into the appropriate jacks. They jacks are usually color-coded to match the connector type. Then check to make sure the plug that connects to the back of your console is in the correct port and is snug as well. A loose connection anywhere will prevent anything from coming up, the PS2 was infamous for that.
Aside from issues with A/V, be sure your TV is on and tuned to the correct source. If your PS2 plugs into an RF switch which plugs into the coaxial (cable) port on the back of your TV, the channel should match what the RF adapter is set to before turning on the console. If the PS2 is plugged into your TV through the A/V cables (The yellow, white, and red connectors we discussed earlier), make sure your TV is set to the proper source. The source channels could either be labeled "Video 1," "Video 2," or "Video 3," depending on your configuration. Also, the source could also be labeled "Game."
If none of the two solutions above work, then it appears your PS2 has bitten the dust. Best thing to do is give it a nice tombstone with a beautiful eulogy to make even the most battle-hardened tough guys cry like a baby
May 04, 2011 | Sony PlayStation 2 (PS2) Console
I got a mitsubishi flat screen tv and also a ps2 but i dont know how to connect the 3 color things because there are alot of colors on the back of the tv
White=audio Red=audio Yellow=video
Just make sure you plug them into the same input cluster, it should be outlined on the back of the TV.
Feb 22, 2011 | Video Game Consoles & Games
How to on ps2
  • Find a clear space, preferably out of direct sunlight, to set up your PlayStation 2.
  • Plug the AC adapter into the designated area on the back of the PlayStation 2 and then plug it into the wall socket.
  • Plug the RFU adapter or audio/video cords (depending on the model of your television) into the back of your PlayStation 2 and then into your television.
  • Plug your controller into the controller slot adjacent to the disc tray.
  • Plug your memory card into the memory card slot above the controller slot (see "How to Managage a PlayStation 2 Memory Card").
  • Turn your PlayStation 2 on using the on/off switch on the back of the PlayStation 2.
  • Press the eject button to open the disc tray. Insert a game disc and press the eject button again to close the tray and begin play.
  • Turn the PlayStation 2 off when done playing by either flipping the on/off switch or pressing the sleep button.
  • Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
    Dropped in snow green light comes on but nothing else does
    The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well. Connecting to a Television Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom. Look for inputs marked Audio and Video IN. Do NOT connect your system to anything marked OUT. Don't see these inputs on your TV? Click here. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console. Insert the AC plug into a 120V AC wall outlet CAUTION: To prevent electric shock, match the wide blade of the plug to the wide slot and insert fully into the outlet. Plug the transformer into the wall outlet. The Sensor Bar can be placed either above or below your TV screen. Decide which option best fits you and click the image below for additional set up help, including mounting the Sensor Bar and proper alignment.
    Jan 24, 2011 | Nintendo DS Lite Console
    It is sync and i can see the status on the upper left corner of tv but cant get it to function?
    Please follow these same steps for your SP3 The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well. Connecting to a Television Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom. Look for inputs marked Audio and Video IN. Do NOT connect your system to anything marked OUT. Don't see these inputs on your TV? Click here. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console. Insert the AC plug into a 120V AC wall outlet CAUTION: To prevent electric shock, match the wide blade of the plug to the wide slot and insert fully into the outlet. Plug the transformer into the wall outlet. The Sensor Bar can be placed either above or below your TV screen. Decide which option best fits you and click the image below for additional set up help, including mounting the Sensor Bar and proper alignment.
    Jan 23, 2011 | Sony Playstation 3 (PS3) Console
    I formatted my wii and it says must have a update from the shop channel if necessary, add wii points
    Jan 22, 2011 | Nintendo Wii Console
    Who to do set up for wii game
    1. The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well.
      • Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom.
      • Look for inputs marked Audio and Video IN.
      • Do NOT connect your system to anything marked OUT.
      • Don't see these inputs on your TV? Click here.
      1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console
    2. Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console.
    3. Insert the AC plug into a 120V AC wall outlet
    1. Plug the transformer into the wall outlet.
    Jan 12, 2011 | Fisher PC-25R20 25" TV
    I need a printable version of how to hook everything up. Please. We have a PlayStaion2
    1. Place your ps2 in an area that will allow for plenty of airflow, and is relatively close to the television that you intend on hooking it up to.
    2. Step 2 Check your TV or monitor for available video inputs. The most common are composite cords, which come with a new PS2. This cord has one plug on one side, with the other side having three ends colored yellow, white and red.
    3. Step 3 Plug the single end of the video cord into the back of the PS2. Plug the other side of the cord into the corresponding colors in your video input on your television.
    4. Step 4 Plug the AC adapter (power cord), into the back of the PS2. The other side of the cord should then be plugged into the wall. A red right will appear on the front of the PS2, signaling that it is on standby mode, and receiving the required power.
    Jan 05, 2010 | Sony PlayStation Portable (PSP) Console
    Connecting Sony PS2 to Panasonic HT32LZD85
    First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
    Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
    If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
    Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
    Oct 03, 2008 | Panasonic Televison & Video
    Super nintendo ac adaptor
    About the ac adapter is to power the console unit. There are also audio/video cables. On the back of the tv there should be something that says audio in/ video in. In that section match the colors up and connect them. Also look in your manual for audio/video input setup.
    Thanks,
    Brian Henry
    http://www.vgr-techs.com
    Jan 13, 2008 | Sony PlayStation 2 (PS2) Console
    Sony PlayStation 2 (PS2) Console Logo
    1,031 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Ekse
    shevantha perera
    Damen Wong
    Damen Wong
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
