Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Samsung HLP5063W - Vertical Lines
We have vertical lines in groups of eight with empty space in between almost as if they were columns. The lines appear on top of the picture. Changed out the bulb but that did not fix anything.
Also, there is a clanking sound when we turn on the set - this does not happen all the time but does not sound good.
Any idea?
What is the problem?
How do we fix it?
Thanks.
  • 7 more comments
  • cicada55 Dec 04, 2007
    I also have the same problem. The vertical lines are white and will flash on the screen during some scenes. The lines do look like columns that are made up of smaller lines (|||| |||| |||| |||| ||||)
  • Anonymous Dec 05, 2007
    vertical lines in columns of eight with space in between columns, same as other person
  • damienko2001 Jan 03, 2008
    I turned on my TV today and have the vertical line issue. I turned it off and waited a bit and turned it back on - the lines dissappeared. I do not know what the root cause is.
  • POdSmsngUsr Jan 09, 2008
    samsung HLP4663w 46 in. Last night while watching TV, 10 columns consisting of eight thin verticle lines appeared on screen and will not go away. any assistance would be greatly appreciated. Product warranty has expired; notified Samsung tech, and they had little to say except perhaps it is the color wheel (though i do not hear 'clanging' that others have described). Samsung refered repair shop believes repair will be roughly $700 (yet do not know exactly what the problem is!!!).
  • POdSmsngUsr Jan 23, 2008
    Yes, my local tech (w/ Samsung tech support aid) has come to the conclusion that the DMD assembly is bad. Your suggestion was helpful and I scored it so.
    I wound up filing a complaint w/ Samung Executive Consumer Relations (or something like that) to try and get the repair reimbursed. The outcome for our claim is still pending.
  • bon_temps Jan 27, 2008
    I have precisely the same problem, but with a little more info. I'm fairly capable electronically, so I fiddled around with the sset a bit. I've discovered that when the vertical lines are present, I can deflect the top right corner of the DMD assembly with a screwdriver, and the lines will dissappear. This result is absolutely consistent. There's clearly a problem with a bad connection inside of the DMD assembly. I've taken this thing apart, and I know that the DDP chip is not soldered into pace, it uses a compression clip to mate it up to the main board. I suspect that the problem lies in this arrangement.
  • bon_temps Feb 26, 2008
    I finally broke down and ordered a new DMD board and it did fix the problem. Was a little tricky to get alignment and squaring set back up, but it looks beautiful again.
    An interesting side note is that SamsungParts.com now has the DMD board listed for $528.73, which is $400 less than in December.Must mean refurbished. They also offer a $50 core credit if you return the old one. Obviously, they are dealing with a lot of this.
  • Anonymous Jul 20, 2008
    We have he Samsung DLP HL-P4663W 46 in TV.  We have 10 sets of vertical lines on the screen.  We really are hoping that we need to just replace a part.
  • cmfrank3 Jul 20, 2008
    We have the samsung DLP HL-P4663W TV and are experiencing 10 sets of 8 vertical lines on the screen.  We are hoping that replacing a part will fix this problem.
  • 71 Answers
It's realy bad guys. It looks like DMD defective. If I could see a picture...?
Posted on Dec 10, 2007
  • Eduard P Jan 23, 2008
    Before you rate a solution please read what it is. You rated it "tft" when the solution is real and correct. If after what you described the DMD is not defective I'm gonna fix it for free for you. If not... I'll wait for your public appologise.
SOURCE:
Vertical lines
I called a local tv repair shop he said that he'd have the see the unit to give an exact price but their labor rates were from $79.95-$179.95 + parts =(
Jan 10, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
I have a Samsung hlp5063w and now it has white vertical lines...is there a problem with circuit board or DMD?
hello,
Just for share, i have experience like your problem.
If your problem like picture below, thats DMD defect.
Replace it.
I hope thats will help you.
Mar 10, 2011 | Samsung DLP HL-P5663W 56" TV
I see 11 flashing groups of about 4 ununiformely-doted lines (black and white) on my screen. Ech group of 4 lines is separated from the next by about the same width of the group (i.e. the screen is divided...
there maybe some problem with the vertical circuits with your tv, if you are still satisfy and tv is viewable then patiencely watch it. however as times goes by using it, if the defect is not corrected it may worsening the vertical circuits problem. scanning vertical trace is the problem of your tv.
Feb 06, 2011 | Pioneer PDP-4271HD 42 in. Plasma...
A group of 16 vertical black lines have appeared
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Mar 26, 2010 | LG MZ-42PZ14 42 in. Plasma Television
Sets of vertical lines
why do you bother with the free service. Do you just keep sending email requesting money.
Jun 27, 2008 | Samsung HL-P6163W 61" TV
Bad lines on Infocus IN24 images
Hi Dan
The only way to get rid of this is to either have the Mianboard repaired or replaced.
If the Projector is stil under warranty - it will cover it.
If not - It is quite expensive !
Hope this helps you.
Nov 24, 2007 | Office Equipment & Supplies
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
338 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
