Question about Rio Carbon MP3 Player
Jeep liberty When I turn on the A/C or heater in my vehicle it will not work unless it is on the #4 position of the "amount" selector.
  • 8,596 Answers
Wrong section
Posted on May 23, 2008
Heater only blows hot air intermittently.
Jeep Liberty heater not blowing hot air Questions & Answers ...
www.fixya.com > ... > heater not blowing hot air > Cars & Trucks > Jeep
Jeep Liberty cars & trucks heater not blowing hot air questions and answers. Ask your Jeep heater ... My 2005 Jeep Liberty will not blow heat through ... properly.
jeep liberty 2002 heat problem/hvac box issue - YouTube
? 3:12
https://www.youtube.com/watch?v=xf22fvcN1hU
May 28, 2013 - Uploaded by Joffre richer-desroches
Joffre richer-desroches. ... How To Install Replace Engine Coolant Thermostat and Housing 3.7L 2002 ...
Nov 01, 2015 | 2005 Jeep Liberty Sport
Why can't I get the key in my jeep ignition to turn to lock and come out of the ignition?
It may be a malfunction in the gear selector safety switch with it saying 'hey, I am still in gear and you can't do that until I am in Neutral or Park.'
Try cycling the gear selector a few times.
Jul 23, 2014 | 2006 Jeep Liberty
Leaking coolant fluid a good amount almost a stream when I shout the jeep off near the fire wall on my jeep liberty. Temp gauge is reading fine
You have a bad heater core it needs to be replaced soon, your system cannot maintain pressure and you will have massive issues and failures due to this and you will have to replace alot more than just your heater core. I hope this helps you
I’m happy to assist further over the phone at https://www.6ya.com/expert/brock_d67526d2a834c47e
Dec 14, 2013 | 2002 Jeep Liberty
Jeep liberty heater/defrost
check the actuator motor or motors on the heater. It is inside on the base of the heater and directs the air where you want.
May 09, 2017 | Cars & Trucks
2012 jeep liberty heater
If you find that the heater control is a problem then until you get an answer, try running the ac unit as well. It will dehumidify the cab air ( no fogging windscreen ) keep the cab at a reasonable temperature . In most cars it is referred to as climate control . Control is by the heater knob as to how hot you allow the heater to get
Nov 30, 2013 | Jeep Cars & Trucks
My 2002 jeep liberty 3.7L the heater stop blowing it was working on the number 4 setting now it dont work at all. no heat
this sounds like the heater motor resistor has gone bad and needs replacing.this controls the amount of voltage that goes to the blower motor to give you the different speeds.if it was the blower motor it wouldn`t have worked on #4 setting before stopping.this us located in the air box as it uses the air flow from the motor to help keep it from getting too hot,usually in the area of the motor and has about 5wires connected to it.
Oct 19, 2011 | 2002 Jeep Liberty
I own a 2005 jeep liberty. the ac, heater fan only works on selector switch setting # 4. nay sugesstions on why fan does not work on settings 1, 2 or 3.
The lower speeds are accomplished by running the power supply through various resistors that drop the voltage which makes the blower turn at different speeds. The lowest setting uses all the resistors to drop the voltage as much as possible to turn the blower as slow as possible. High speed uses no resistors so the blower gets full power and turns as fast as possible.
Since speed 1 and speed 2 use the speed 3 resistor to drop there voltage and speed three is not working as well my guess is the speed three resistor is burnt out in the device referred to as the blower motor resistor or blower motor speed control module. This is located near the blower motor and is held in place with 2 screws. There will be several wires and possibly two connectors plugged into it.
These are really common failures in many vehicles. The parts are usually available at your local auto parts store and they are typically not that expensive.
Hope that helped.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 07, 2010 | 2005 Jeep Liberty
My Jeep 2003 Sport, heater only works on #2 &
You heater only works on speeds #2 & 4 because the blower motor resistor pack is defective. Replace it.
Jan 02, 2010 | 2003 Jeep Liberty
Heater only works on 3 and 4 setting
Your heater motor speed selector only working on a couple levels is caused by a faulting blower motor resistor.This part is located on the evaporator case next to the blower motor itself.Two bolts remove the resistor and an electrical pigtail finishes it off.The location of this is underneath the dash on the pass front side.Happy Holidays!!
Dec 10, 2009 | 2004 Jeep Liberty
2004 Liberty -- Tire Sensor
Turn Ign. key on but only to on position do not turn to start position, now look at dash instrument cluster for a 4 tire diagram of vehicle as if you were above the vehicle looking down. It will show middle of cluster and even show all 4 tires in proper position on vehicle . Now when one tire is low below 30 psi it will light the tire in the position on vehicle located for you the tire with issue...
Sep 11, 2009 | 2004 Jeep Liberty
Rio Carbon MP3 Player Logo
18 people viewed this question
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
