Problems with a Mitsubishi Big Screen
We have a Mitsubishi Big Screen Television Model number VS-5059. There is to much red and we can't get rid of it. We have tried adjusting the blue and red. Is there a reset button that needs to be pushed.
Thank you for your support.
Leslie Rinehart
  • 88 nascarfan Dec 06, 2007
    Do they have settings for the blue, red and green. We can't seem to get them dialed in correctly.
    Thank you
  • 88 nascarfan Dec 07, 2007
    We have dialed it in and it still has alittle to much blue that we can't seem to get out and any writing that is on the tv is alittle blurry.
  • 1,694 Answers
Where did you adjust the red and blue?................Did you remove the speaker grill cover and the access panel to get to
the screen control adjust? Do not adjust focus..........make
sure you turn down ( CCW ) the red screen control a little....
is that any better...........?...................T.
Posted on Dec 03, 2007
  • 1 more comment
  • Vista Electronics Dec 06, 2007
    The settings are as previously described....I can't tell if you
    turned down the red screen control........?
  • Vista Electronics Dec 07, 2007
    Too much blue = add a little more green and red,if it does
    not balance, then pix tubes are weak.......................T.
    Blurry = adjust RGB focus Up Front............T.
Mitsubishi VS-55609 distorted Picture Flickers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
May 14, 2010 | Mitsubishi VS-5059 50" Rear Projection...
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
I have a mitsubishi vs 5059, when i open the TV I get a black square covering most of the tv but i can hear the sound and also see the picture outside of the black square. I don't know if there is an error...
You can likely buy a replacement remote here:
'Universal' remotes exist only in your dreams; there is no such thing since the manufacturers cannot agree on a basic code set that would work with any set. None of them can control every function of every brand and model made.
Sep 27, 2009 | Mitsubishi VS-5059 50" Rear Projection...
Mitsubishi VS 6041. Just began having problems
Replace Both of your STK ICs example STK394-250 they are big black ics will have part number on them Call Mats 1-800-628-1118 for parts.
Sep 16, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi big screen tv
Do the self test first find the error code. Look on here or
Jan 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Problems with t.v.
remove crt board one at a time,when set comes on and stays on then that tube is shorted, try red first.CRT on NECK of tube!
Nov 19, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-55609
Can anyone tell me where the horizontal driver xformer is on the VS-5059?
Oct 23, 2007 | Mitsubishi VS-5059 50" Rear Projection...
Mitsubishi VS-5059
ic stk392 110 replase chak resistors 2.2ohm
Aug 11, 2007 | Mitsubishi VS-5059 50" Rear Projection...
Mitsubishi VS-5059 Problem(S)
These sets are very hard to fix.however you can go to and buy a schematic for that set.and your trouble will be over it will cost you abut $40.00 US.Good luck
Jan 14, 2007 | Mitsubishi VS-5059 50" Rear Projection...
Mitsubishi VS-5059 50 in. Proj. Televsion
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. This should not be an expensive job at most repair shops. Could be something as simple as cracked, cold, defective solder joints around and near the vertical output chip, could be a faulty chip and other components in and around the vertical deflection circuitry, or a faulty vertical drive signal from the jungle circuits, or worst case a faulty deflection yoke. Take your television to a shop right away for a proper and safe repair. Do not keep the television looking at the red horizontal line.... you can easily damage or burn the CRT phosphors. Good luck
May 27, 2006 | Mitsubishi VS-5059 50" Rear Projection...
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
