Question about Jet Tech Systems STEALTH Dishwasher
Maytag quiet series300 jets not spinning
The jets seem to be not spinning when I try to run a wash or rinse cycle. All you hear is a hum. I disassembled the bottom spray unit to find it was clean. Did a motor go bad? Is this something I can fix myself?
2 Suggested Answers
  • 5911 Answers
SOURCE: maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
Posted on Jul 31, 2007
Water is leaking under the bottom?
Posted on Feb 03, 2008
0 characters
1 Points
Maytag, model MDB7100AWB, acts spuratic!? 4 days ago it hummed most fo the evening, I just thought it was the fridge. There was water sitting in the bottom when I opened the door - and the humming...
probably the drain pump, access is underneath and to the right of pump housing, the drain hose connects to main housing and the drain motor is right and just behind where hose connects. open door part way for easier access. and use shop vac to remove as much water as possible, then have 2 or 3 bath towels to clean up if you try on your own. local parts house will have drain pump if you take model # with you
Dec 20, 2011 | Maytag MDB7100AWB Dishwasher
I have a maytag washer (model -dependable care) and when we start the wash the motor just hums, the water does not fill, if we move the timer switch to rinse the motor engages and the unit works entire the...
Check your fill tubes remove the hoses and see if the filters are plugged, you are not hearing the motor humming. You are hearing the watervalve humming, the motor will not start until the tube is full of water.
Jul 16, 2009 | Maytag MDB6650A Built-in Dishwasher
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Maytag dishwasher.Loud humming noise, wash cyle,at beginning
Is the water filling up and then draining out? Mine did this and a part was broken inside the unit. The part was five dollars and called a lifter. I fixed it myself.
Jan 01, 2009 | Maytag 24 in. MDB3700 Built-in Dishwasher
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Noisey maytag
Hi, i had the same problem twice and both time there was some plastic stuff in the shredder. Remove the screw in the middle and remove the cap and you will probably find some pieces near the blades.
Nov 11, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
Jet Tech Systems STEALTH Dishwasher Logo
19 people viewed this question
Top Jet Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Jet Dishwasher Expert? Answer questions, earn points and help others
