Question about Pioneer PDP-4360HD 43 in. Plasma Television
Pioneer PDP-436PG In Brazil we started receiving as from today digital signal TV.Everybody is talking here about a converter needed in order to capture this signal. I am a bit confused with the issue.Does my TV neeeds one? Or it does only when a HD signal is transmited?
  • 22 Answers
Bom dia!
If you mean DVB-T signal then you will need an extra box to receive this via a normal antenna if your media receiver does not support digital free-to-air (I don't know your model because I am not familiar with non-european types). At the moment I don't think anybody transmits HD on terrestrial digital. Satellite TV can provide HD transmission.
Posted on Jan 11, 2008
Do I need a digital set top box if I have a pioneer PDP-R05G media reciever
Turn the receiver on and select TV. If you can't tune X.X channels (no decimal), you need the converter.
Apr 02, 2017 | Pioneer Televison & Video
Pioneer plasma model PDP-507XA. how can I tune a TV channel?
The PDP-507XA only has an analog tuner. You will need a set-top box (digital to analog converter) to receive over-the-air signals in most places. For analog cable, you need to set the source to TV. Press the Select button, if needed (it's above and to the left of the arrow keys), to put the remote in TV mode. There is also an Input button on the TV. If the Channel Up/Down keys do not work, you need to reset the TV Press the Home Menu button. Navigate to the Setup menu (Up/Down arrows followed by Enter) and select Auto Installation. Enter your password for the TV; the default password is given in the manual on page 41. It's available from Pioneer here: docs.pioneer.eu/Manuals/PDP_507XA_ARE1430_manual . Set the Language (use the Up/Down arrows followed by Enter. Then use the Left/Right arrows to change the setting). Then set the Country. Press Start to begin a scan for channels. Alternatively, select Analogue TV Setup and enter the password. Then identify the correct receiving system. Manually enter the channels in the Search area. Set Store to Yes to save channels.
I hope this helps.
Feb 14, 2016 | Pioneer Televison & Video
Pioneer Pdp 436pg and receiver user guide
They are available on pioneers web site.
Jan 01, 2015 | Televison & Video
PDP - 436PG display turns off then straight off and the red standby flashes 3 times, pauses then repeats
That is an error code that likely means power supply issue and based on brand not likely to be a do it yourself fix. Consider having a authorized Pioneer service center look at it and get an estimate.
Nov 05, 2012 | Pioneer PDP-4360HD 43 in. Plasma...
(Pioneer PDP-4340HD Plasma with PDP-R04U Receiver) My HDMI input works, however having a computer or Xbox connected via HDMI I do not have the optical output signal thus I can not hear audio through my...
I don't have a direct solution but I am having the same problem when connecting (1) my Apple TV (2) my Blu-Ray player, etc. via HDMI. I also have a digital camera that puts out HDMI, and when I hook it up, I get the same story -- video only, no sound through the optical digital output of the TV receiver.
I am guessing that the HDMI inputs were an afterthought on this model, especially since the printed manual doesn't even show or mention the HDMI inputs at all! So my guess is that the TV's receiver does not convert the sound from the HDMI to the optical digital output. It does, however, send the amplified HDMI sound to the stereo speaker outputs on the monitor. It appears that only the digital tuner's 5.1 sound comes out on the optical digital output.
This is what I have observed, for what it's worth.
Nov 04, 2010 | Televison & Video
5 rapid red blinks on the LED
Solution for error 1, 5 beeps,
For video data transmission from the Media Receiver to the PDP-434HD
and PDP-504HD-series Plasma Displays, digital signals are used.
Therefore, this unit adopts the HDCP (High-bandwidth Digital Content
Protection) system for copyright
protection. This unit is also provided with a detection switch (TRAP
switch) that will prohibit the unit from being turned on again "if the
upper plate of the unit is accidentally opened," in order to prevent
the panel technology from being leaked out.
The TRAP switch is disabled while the unit is turned off. When
performing internal diagnosis of the PDP, fix the switch to the OFF
position using adhesive tape before turning on the
unit. After servicing, be sure to remove the adhesive tape.
Well you've probably guessed what my next question is......How do i
unlock this receiver?. I'm told that it's simply a matter of keying in
3 buttons of the remote in a defined sequence. I have the service
manual but it doesn't say much about unlocking.
"The next generation of Blu Ray players will be equipped with
powerful explosives that will kill everybody in sight if the unit detects
possible tampering or if someone puts a DVD+R in it." )
( They use a photocell to kill the DVI board if light hits it
(as in the backboard removed). The TV continues to work, but not in
HD.
bypass the Pioneer's switch, or put black tape over the photocell.
Sep 30, 2009 | Televison & Video
PDP-436PG
maybe its not worth the effort. the media or turner box must corsponed with the model of the pioneer tv, in order to work.
Apr 09, 2008 | Pioneer PDP-4360HD 43 in. Plasma...
Pioneer plasma PDP-436PG
pretty much imposible. Not worth the money (if pioneer would do it) to fix it. The only this its good for is to sell it for parts the are still good on ebay or w/e. Best of luck
Jun 14, 2007 | Pioneer PDP-4360HD 43 in. Plasma...
Pioneer PDP-4360HD 43 in. Plasma Television Logo
628 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
