On most acers it is two pads or a small jumper hidding under the ram.
With the laptop OFF remove the ram and check for J3 its is usually a bit more distinctive than the normal green pcb
You need to short that jumper out for a second or so
re-install the ram and boot up
You should now be able to get into the bios
(1) Pull cmos cell from motherbord for 10 minutes it is back side of laptop.
Open back side cover of laptop then you find motherbord chjip set .
CMOS cell is round cell pull it .
(2) you can reset it with jumper settings There is 1 jumper named "clear cmos "
It has 3 pins mostly it is near the cmos battery cell find on motherbord it is 1-2 position by defaults for reset cmos you have to set it in 2-3 position then give power up.
then again set it in 1-2 position so all settings are reset.
I am looking for a TRUE desktop-replacement.
I am looking for a quad-core min 4. GB of DDR3...
(More)
I am looking for a quad-core min 4. GB of DDR3 RAM.
I also want a better GPU then just the intregrated one so that I can truely play games hi-res, just search me the best laptop you can find, but not from dell, that includes Alienware.
Thanks in advance
I have a compaq presario XP machine with a synaptics touchpad. I turn of tap click but it gets...
(More)
I have a compaq presario XP machine with a synaptics touchpad. I turn of tap click but it gets rechecked on reboot. The touch pad scroll stays turned off though.
I am trying to clean the dust out of my laptop and I have it mostly disassembled, but the bottom...
(More)
I am trying to clean the dust out of my laptop and I have it mostly disassembled, but the bottom right hand corner (the one with the optical drive) won't separate. I have removed the optical drive but it still won't separate.
my laptop keeps ******** down by its self everytime i turn it on? what should i do without spending...
(More)
my laptop keeps ******** down by its self everytime i turn it on? what should i do without spending money?
