Question about Sharp VL-A45 8mm Analog Camcorder
Eject of tape
The camcorder will not eject the cassett. The door will open but the tape will not eject.
  • 217 Answers
SOURCE: Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Sep 28, 2007
  • 64 Answers
SOURCE: Sharp camcorder vl-wd450
something is wrong with the m-chassis needs repair sorry the chassis on any cameras are very sensitive and they break alot not yor fault.
Posted on Nov 19, 2007
  • 1944 Answers
SOURCE: Sharp video camera VL-AH50
Did you try cleaning the tape head?
Posted on Feb 22, 2008
  • 5568 Answers
SOURCE: Trying to record and display says Eject cassette
May be a stupid suggestion but check the slide lock on the cartridge to make sure it is in the record position.
'Night vision' is a term applied too loosely; it originally referred to the original 'starlight' scope that uses a special tube capable of actually amplifying light particles (photons).  More recently, the phrase has been applied to devices capable of 'seeing' into the infra-red spectrum. Since too much IR sensitivity affects the quality of any digital camera, the sensors are normally designed to be less sensitive to that wavelength.
The fact that none of the specifications mentions the minimum usable light level is bothersome. Most digital cameras (and camcorders) have 2-3 lux ratings which is not in the category of 'night vision' at all.
Posted on Feb 22, 2009
  • 405 Answers
SOURCE: Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Posted on Oct 26, 2009
  • 13433 Answers
SOURCE: Cassette wont play keep getting
this is caused by a malfunction in the tape drive of the unit, a part might be missing, out of place or the drive might be getting stuck.
to correct the problem the unit would need to be taken apart and the drive inspected cleaned, possibly some gears might need lubrication (the type of lubrication that is used in VCR's and other such units) there are many areas to grease and oil. For the inexperienced person the easiest way to find out where to lubricate is to spot the old grease on the mechanisms. Most grease from the factory is either blue or white. All you have to do is give these areas a little dab of fresh grease. Don't over do it. Sometimes to much grease can cause problems,it may smear onto the rubber parts Creating slippage,then you have to go through the process of removing all the grease and that is not easy.
for grease you can use machine lubrication oil if you can find that locally or something similar to this:
the service is quite complex it may be best to take it to a repairer if you feel this is too much. The above is not a guarantee fix, there may be other issues in the drive that we don't know about at this point.
Posted on Feb 06, 2011
0 characters
1 Points
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
Oct 30, 2009 | Canon Elura 90 Mini DV Digital Camcorder
Cann't eject cassette from Canon ZR60
I had a similar problem last few days with my ZR60.
The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own.
I was messing with it a little bit and realized that the door was not opening fully. Being a delicate item I didn't realize that I was not fully opening the door may be because there was a little friction in the pivot pins or what ever.
Try to gently swing the door open fully and see if it helps.
Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it.
I was almost going to give up this camcorder last night thank GOD, I am able to use it.
Good Luck to you.
Dec 27, 2008 | Canon ZR60 Mini DV Digital Camcorder
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
May 05, 2008 | E.Digital Sharp VL-Z7E Digital Viewcam...
Cassate tape will not eject from my Canon ZR85 Mini DV Digital Camcorder
I found a temporary solution for this problem. When the tray with the cassette tape comes out remove the battery so that the tray will not go inside again. Now on top of the tray it will be written as "PRESS" just adjucent to it you can see a spring connected to the tray just press the string down wards and the tray opens and you can replace the battery. Hope this can help.
Feb 01, 2008 | Canon ZR85 Mini DV Digital Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Sep 10, 2007 | Video Cameras
Removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Jun 06, 2007 | JVC GR-D270 Mini DV Digital Camcorder
Tape door will not open
the tape eject door will not open there is currently a tape in the camcorder (panasonic pv-l559)
Jan 09, 2007 | Panasonic PV-L559 Camcorder
Sharp VL-A45 8mm Analog Camcorder Logo
22 people viewed this question
Top Sharp Video Cameras Experts
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
