Question about RCA P52926 52" Rear Projection Television
RCA P52820BL Projection TV - Video intermittently works???
This has been a recurring problem for some time. Once in a while my SVID input seems not to work. I had to switch to SVID since my COAX input did the same thing years ago (the coax no longer works all together!!). Is this a problem with the VIDEO switch on the board since VID1 still works with my XBOX??? Now it trys locking on the signal between ANT and SVID, switching back and forth finally giving me the UNUSABLE SIGNAL message...... Any help would be appreciated!!
  • Anonymous Feb 08, 2009
    need Manual for P52820BL Need to adgust color by aliening guns ,cant find right menu to fix
    President:
  • 4,402 Answers
Bad ground on tuner or bad tuner
Posted on Jan 09, 2008
SOURCE:
Where is the coaxial for model number 57hc85 serial no 26101140 chassis no tac 506 we cannot connect a signal at all we bought a modulator rf but it's asking for asking us to connect 1 into the tv but...
After some research http://www.tacp.toshiba.com/tacpassets-images/models/51hc85/docs/51hc85_om_e.pdf There is no coaxial input for this tv. Also as far as the RF Modulator you unfortunatly are trying to use that incorrectly. The RF Modulator is used to convert the RCA or Red Yellow White cables down to Coaxile, not vice versa. However if you have an old VCR or better yet a cable box you would want to hook up the cable box then enter the TV using one of the RCA jacks, HDMI Jacks, or other inputs such as Svid. But easy enough if you have a vcr you can access cable through that as well, and make sure the tv is sat to the correct channel or input to access the VCR or other item.
Feb 04, 2011 | Toshiba 42H81 42" Rear Projection...
High pitched whine/sometimes TV won't turn on
The power supply on this model will whine when it is shorted or overloaded - the set would have to be brought in to determine exact cause.
Oct 23, 2009 | Televison & Video
RCA P52820BL Chassis PTK195DB Will not power up
This is going to be the flyback transformer part# 239111. Very common problem in these sets
Jul 09, 2009 | RCA P52830BL 52" Rear Projection...
RCA HD52LP: Composite video inputs don't work
RCA Authorized service tech looked at it. He determined that the DM Module need to be replaced. The part alone costs $550 + labor. Since the HDMI and component video inputs seem to work, he suggested buying a VCR DVD combo with HDMI output which would be far less than repairing the tv itself. I'n researching the possibility of purchasing the part myself.
Jun 08, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
The who input button
usually a tv that doesn't "see" video on the S-video will not even "switch" to it.  It just goes to the next Svideo, RCA etc..
Make sure your cable is not damaged. (on both ends) Does the svideo source and svideo cable work with another tv or video device?
31GT740 Manual From the Manual:   " WHO•INPUT In TV mode, press WHO•INPUT to toggle through the available Video Input channels (VID/SVID and the current channel). In SAT mode, press to select available channel lists.
Using the WHO•INPUT Button Use the WHO•INPUT button to toggle through the available input sources (VID and the current channel) and view the content from the component you have connected to the TV. 1. Press TV to place the remote in TV mode. Make sure that the content from the component is turned ON. 2. Press WHO•INPUT to tune to the available input source and view the component. 3. Press WHO•INPUT again to tune back to the channel you were previously watching.  "
James Mac
Sep 10, 2008 | GE 31GT740 31" TV
My rca home theater tv guide plus mod#p52820BL
Can you try using a different video cable?
May 08, 2008 | Televison & Video
Operating a SONY DVD player with RCA TV
The only thing I can think of is that you have the input option on the wrong input. Have you tried pushing the input button or TV/Video button? I hope it helps...
Feb 23, 2008 | RCA F27664 27" TV
RCA CTC203 No Colour in the Video IN or Svideo but colour is present on tv channels.
try removing your vcr and dvd connections first while watching TV programs alone!. if still there are no colors then your tv have a problem!
Dec 05, 2007 | Televison & Video
No picture with vhs
Don't pass the video sample through the Onkio.. Use a second single RCA patch cord to go from vcr to TV... Use the same yellow out on the vcr that you're using now and send it directly to the yellow video input you're using on the TV..
Hope that's clear - I'm getting tired...
Bill
Dec 02, 2007 | RCA TruFlat 27F520T 27" TV
Technical help
You need an audio y cable - That is a cable with a headphone jack (to plug into the speaker/line out jack on the laptop) and on the other end 2 rca jacks (they need to be plugged into the left and right audio inputs on your tv but make sure it is the same inputs that work with the s-video cable) That should get you sound on your tv. You can get 1 here: http://www.newegg.com/Product/Product.aspx?Item=N82E16812196019 Or pick 1 up at your local $1 store. Or if you have an old pair of headphones, rca jacks and wire you can even make one.
Sep 17, 2007 | Televison & Video
RCA P52926 52" Rear Projection Television Logo
126 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
