Question about Sony KP-57WS500 57" Rear Projection Television
Screen issues Our TV has red and green hues all over the screen. For instance, on the bottom of the screen when my kids watch the Disney Channel the Disney Ears on the botton left of the screen appear in red and green. Also, a person in the middle of the screen has a green hue around their head. All of the video channels do it, whether it is on video, dvd, or regular tv. I've called it in but they suggest I take it in. Unfortunately, it is 54" and I can't just drop it by a repair shop. Any suggestions as to what has happened and can we fix the problem ourselves? Thanks!
  • 1 more comment
  • cshearer6 Dec 03, 2007
    I guess I should mention that it is a Sony Projection TV, 54"
    Hi and thanks for the post. It is a KP-57HW40, and manufactured 1/2002
  • niners016 Aug 05, 2008
    I'm having the same problem. How many convergence does this TV have so I can order the correct amount? Is there an instructions on how to replace it?
    Thanks
    Genius:
  • 1,694 Answers
For accurate info,please give model # and mo / yr built off
sticker on back of set..............Let me know ASAP please...T.
Posted on Dec 03, 2007
  • Vista Electronics Dec 03, 2007
    Thank you for info = five year old 57" = probable bad convergence IC........circuit board must come out ......replace
    both STK392-560 IC's.................................T.
SOURCE:
My daugher has a disney princesss tv and the screen is green but has volume why is that?
Most likely a issue with the green gun in the picture tube or on the circuit board that plugs to the end of the tube, it will have red,green, and blue amps on it.
Bottom line may be that for this set it might cost too much to repair.
Dec 19, 2012 | Televison & Video
There is a green hue around the objects and people on the screen how do i fix this
Hope it is just cleaning take off the front screen. I think on that model remove the speaker covers, and a row of screws holding the bottom of the screen remove them. Watch the wires to the front buttons there may be a connector or two to undo. Carefully lift up and toward you WATCH THE WIRES. With a dry clean cloth wipe off the three CRT tops and the back mirror. Put back together and see.
If you still have a green hue.
Remove the screen again. With a flash light look down the CRT's if they a real cruddy down in the coolant yes there is liquid coolant in them. The red doesn't have this trouble but the blue and green can get contaminated. Also look for leaking of the coolant down on the boards. There are procedures to clean and repair leaks. Let me know.
There are a couple of focus procedures which I don't think is your issue.
Good luck Mark
Oct 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
MY SONTY WEGA TRINITRON HAS A PURPLE HUE AT THE TOP OF THE SCREEN. ALSO THE CHANNEL DISPLAY WHICH IS NORMALLY GREEN ON COLOR IS NOW A RED COLOR
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony, tv comes on color fine, then turns red
I had the same problem with my TV, but the hue was blue. I was told that not only did I have to replace the picture tube that wasn't staying on, but I would have to replace them all because they would not mix properly. After much investigation, I found that there is an adjustment for a variable power supply to each tube that can brighten and lighten each tube. I adjusted the RED pot and my picture color issue was resolved! To access this adjustment you must remove the front panel on the TV. At the bottom corners there are two small screw covers that you must remove. Then un-screw the screws under the covers. Then pull the front panel off of the TV, (it hooks under the top near the screen so it will swing out from the bottom). Now remove the wooden panel in the center, (four screws). The pot adjustments are at the bottom of the TV. They are marked for Red, Blue, and Green. They are extremely sensitive, don't turn them much! If you over adjust you will get red, green, or blue lines on your screen. Adjust back down to remove these, (this is also the remedy for removing these lines that can appear over time). Good Luck and God Bless!
Mar 17, 2009 | Sony KP-51HW40 51" Rear Projection...
Vizio 37" LCD color problem!
is the TV still under warranty. if it is I would call Vizio and request a main board be switch and if it is not under warranty I would call a TV Repair shop and have them put in a Main Board.
Mar 04, 2008 | Televison & Video
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
How to erase parental control code
I finally found out how to reset the V-chip password on this princess DT1350-P Tv. All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
Nov 12, 2007 | Disney DT1350-P 13" TV
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
Red and Green
A screen drive issue is at hand and will require the help of a shop to get it back up to snuff....accordianman
Sep 11, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
Sony KP-57WS500 57" Rear Projection Television Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
