Question about JVC AV-27530 27" TV
JVC AV-27530 27"
TV won't turn off (using panel or remote), has no picture or sound. Put a new battery in remote. No buttons on remote or panel work.
Don't know if it is a TV problem or one of the kids pushed some wrong buttons. TV is 2 years old. Please help.
  • 1 more comment
  • Anonymous Mar 01, 2008
    have green light on front panel but will not turn on at all like it is in timer mode
  • Anonymous Mar 19, 2008
    I have the exact same problem with my JVC AV-27FA44. It will not turn off! Trying to turn it off only mutes the sound and turns off the 'On/Timer' light. Pressing 'On' after this makes the picture disappear for a split second, then the picture comes back and there is sound.
  • jed608 Feb 21, 2009
    I had the same problem last night 2/20/09.... all i did was unplug the set for a few minutes then plugged it back in ....but now my color is messed up ...too much red in the picture my display for the volume and channel select used to green & yellow now they are Blue & red???? my picture even in animation glares too much red contrast....im puzzeld...
  • 50 Answers
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Posted on Mar 22, 2008
SOURCE:
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
I lost my remote and can't change the channel on the control panel. It is on channel 02 and it won't change even when I hit the channel+ or channel- button.
Hello.
Your problem is stuck keys in your T.V. It usually just needs cleaning, BUT it is hard to clean, because you gonna have to open up the whole TV. I advice you just buy a new remote from JVC or just buy a "Universal Remote".
Jul 18, 2011 | JVC AV-32D305 32" TV
My JVC 27" can not be turned on or off with the remote or the on an off button. Any ideas?
try all in one remote/it can be the infrared on tv not picking up signal/point remote does light flash on tv ?
Dec 23, 2009 | JVC AV-27530 27" TV
A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
Mar 20, 2009 | JVC AV-32320 32" TV
JVC av-32fa44 The menu (picture, sound settings, etc)will appear and scroll through all the settings continuosly, and remote cannot close the menu. Power off tv for a minute will clear the problem, but...
Sounds like one of the front panel buttons is jammed. press each one and see if any fail to "rebound" or feel different from the rest. You can usually work the button in a 'circular motion" to release it. If the buttons seem normal , it's possible that the switch inside the TV has collapsed
Mar 10, 2009 | JVC AV-32D305 32" TV
How do i get out of lock on my tv
This set has a front panel MENU button which is good, since most universal remotes don't seem to work the TV menu.
Use the menu button to get to the closed-caption setup and make sure it is turned off. The black square is because the captioning is set for text mode. That part of the screen is being blacked out so the text (which isn't there) can be displayed.
Nov 14, 2008 | JVC AV-32D305 32" TV
JVC AV-48WP30 48 in. Rear... Problem:
Take the batteries out of the remote control. Press every button 2 times. Then re-insert the batteries. While doing this unplug the TV and hold the power button down for 30 seconds. Then let go and leave the TV unplugged for 3 min. Then turn tv on do a channel scan and then try yhe remote.
Jan 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc tv on button flashing on av 48wp34
Use remote, sounds like Tv is in child lock
Dec 21, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-27530 27" TV Logo
139 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
