Question about Canon PIXMA MP780 All-In-One InkJet Printer
Please wait? I have been leaving my machine off because the fax was intermittenly disconnecting regular calls on the phone line. When I turned it on last week, it began to blink "Please wait" and is completely frozen in that status. I cannot turn the machine off. If I unplug it and then plug it back in, it's on and blinking Please Wait. In addition, the computer sees it as being offline. I have no idea how to get around this. Any suggestions?
  • 5 more comments
  • Anonymous Feb 29, 2008
    I have the exact same problem. Re-installing did not help. Ugh!
    please wait
  • Anonymous Mar 06, 2008
    I have the same problem and reinstalling the software won't solve the problem
  • willowmabel Mar 29, 2008
    please wait is flashing and will not start up
  • Anonymous May 26, 2008
    Checked all cables and tried unplugging with no luck. Still blinking.
  • Anonymous May 27, 2008
    I have the exact same problem. Please Wait?
  • ahnetmail Aug 22, 2008
    Same here; does any1 know of a hard reset feature on this machine? A button seq. possibly? Reinstalling drivers, etc. does not solve the problem. it's a HW/SW issue w/in the printer, most likely.
  • 2,427 Answers
Unistall the device and its drivers,,
replace it and reinstall the drivers..
Just take the device out
right click on my computer then click properties,
click on the hardware tab then select device manager right click anywhere in the box that opens (on one of the device in the tree list) and select SCAN FOR HARDWARE CHANGES,
shut down when its doe and replace the device
go back to the device manager and scan for hardware changes again , if it can find the drivers u will need to reinstall it with the driver cd you got..
WELL THAT WILL SLOVE YOUR PROBLEM
Posted on Dec 31, 2007
  • Rishi Roshan Ali Jan 10, 2008
    hey did you read our suggestions ?
What is an error 283 on a hp officejet J6400
Definitions
  • A communication failure occurred between the two machines.
  • The user at the remote machine might have pressed the Stop key.
  • The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine.
  • The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted.
Solutions
  • If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM (c00060802) (in English).
  • Set the host machine to receive at a slower transmission speed.
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems
    Aug 31, 2011 | Office Equipment & Supplies
    We cannot receive faxes. Gives a busy signal.
    Unplug the phone line from the machine. Wait a few minutes then try calling your fax number from a phone while leaving the phone line disconnected from the machine. If it rings fine from the phone, then re-install the phone line to the fax machine. Try making the call again. If you now get a busy signal then the modem in your fax machine has gone bad and is holding the line open. Make sure when installing the phone line you are placing the cord into the "line" port on the machine and not the phone port.
    Good Luck and thank you for using Fixya.
    Mar 18, 2010 | HP LaserJet 3050 All-In-One Printer
    What is the meaning of eror 232*
    Error Code: 232
    Solutions
    • If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM .
    • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems.
    Nov 04, 2009 | HP OfficeJet J4580 All-In-One Laser...
    HP office jet 6210 All - in- one /error message 232
    Please consult this page for links to fax error codes for your printer.
    In particular, Error 232 yields this info:
    Error Code: 232, 233, 234, 235 ECM, 236 ECM, 237
    Definitions
    Solutions
    You can also access the home support page for your printer here., in case you should have further troubles.
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Jul 24, 2009 | HP PSC 2410 All-In-One InkJet Printer
    Error Log Result 232... The telephone connection was lost.
    Error 232 Definition A communication failure occurred between the two machines. The user at the remote machine might have pressed the Stop key. The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine. The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted. Check the following items: Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol. Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product. Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines. Try sending and receiving faxes on a different fax line. Try using a different telephone cord. Have the phone company test your line for static or noise problems. Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly Solutions If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Set the host machine to receive at a slower transmission speed. Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Jun 09, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Problem faxing
    Unplug the fax at the wall jack and hook up a regular phone. Listen to the dial tone. It should sound like a regular dial tone.
    Next, plug the fax back in and call the machine from a regular phone.
    You should hear fax tones.
    Sep 07, 2008 | Office Equipment & Supplies
    HP G85 auto-answer
    yeppers...same thing happens to mine. So, I simply set it to receive faxes manually now.
    Jan 18, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
    Brother 1270E won't receive faxes
    make sure the phone line is plugged into the port marked "line" not "phone"
    Jun 14, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
    Canon PIXMA MP780 All-In-One InkJet Printer Logo
    396 people viewed this question
    old marine
    old marine
