Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Mitsubishi WD-62327 no pix and no sound
TV will not come on, no sound and no picture. Was working fine when I went to bed last night. I tried to turn it on this morning and nothing.
If the lamp is bad do you still get sound?
Don't you get some type of warning before the lamp goes out if that is the problem?
  • 1,153 Answers
First do the self diagnosis test, search threads here or go to
Posted on Dec 03, 2007
We replaced the lamp in a tv mitsubishi wd-62327 now there is a orange flashing indicator what?
if the set is now working,its just a matter of resetting the lamp-hour counter in the on-screen sure to clean any filters associated with the fan which cools the bulb,or your new lamp wont last long!
Jul 31, 2011 | Mitsubishi WD-62327 62" Rear Projection...
My tv was caught in a flood in the basement. IT is moded number WD 62327. For insurance purposes, can you please tell me when that model was last made and if I were to replace it today, what would the...
12 Jul 2006 ... Prices from $2145 ' Pros and Cons, Videos, Amazon Reviews, and Support. Read the full unbiased report on the Mitsubishi WD-62327. - United States - Cached
Hope that helps.
Feb 16, 2011 | Mitsubishi WD62327 TV
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung PS50C91HDX Sound but no picture
It sounds like the main board or screen may have gone
Sep 26, 2009 | Samsung 50 in. Plasma TV
Blue screen and steady green status light.
mitsubishi will rebuild the chasis for $200 with a 6 month warranty 1-800-553-7278
fax 1-706-654-4299
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
How do I install the lamp? how to install bulb mitsubishi wd 62327
The lamp is in the FRONT of the television set. Just remove the bottom front, no screws, and you'll clearly see directions on how to install the new lamp.
Simple, just a few screws.
Feb 28, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Picture but no sound
OK, I don't have a 360, but are you sure the audio cable is connected, in the correct jack, and pushed all the way in? Sometimes it looks like the jacks are all the way in, but they are not. Thus, no audio. You could also try using Component 2 if that is an option on the TV. Maybe Component 1 ports are bad. Hope this helps.
Jan 24, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Mits wd 62327 "NOT WORKING"
I recently repaired a Mitsubishi DLP for a similar symptom. Found C9a37 and C9a38 in the power supply to be defective. They feed the light engine driver. The power supply module is located all the way up front on the left side of the chassis looking from the rear. The module is also shielded so you will have to remove the shields to locate the capacitors. The value of the caps are 3300mf/25v. Good luck
Dec 14, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi 6043A Loss of color
Sounds like many different problems maybe related thou. You say 6043a but you are under WD-62327. So this info is for that.1. Suspect the Light Engine part # 939P977020 also you could need.. Suspect the Signal PCB part # 930B923002 if no video keeps up
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
144 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
