Back to:
Tags:
Danby 22 in. DDW396 Free-standing Dishwasher
Danby DDW396 Spray Arm
posted by LennyBoi on Dec 03, 2007
I have an issue with the Danby portable, the spray arm does not turn. I have the unit apart and noticed what looks like a pump not turning.
Do these units become plugged or is it because the motor is not turning. Any assistance would be appreciated.
thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 27, 2008
FixYa! (100)
APP-TECH
Rank:Guru Guru
Rating: 87%, 122 votes
I HAD THE SAME PROBLEM AND FOUND THAT DOWN UNDER THE METAL TRIANGULAR STRAINER IS THE PORT
TO THE WATER PUMP. FOOD AND PAPER GOT PAST THE
STRAINER AND COVERED OVER THE INLET PORT TO THE
PUMP. IT IS A SMALL HOLE ABOUT 1 INCH IN DIAMETER
MOLDED INTO THE SUMP AREA ON THE RIGHT UNDER
THE METAL STRAINER, THIS REDUCED THE WATER PRESSURE THAT THE PUMP PUT OUT SO THE WASH ARM
DIDN'T TURN.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Danby DDW396 Spray Arm:
I don't want to Accept this solution
Solution #2
posted on Jun 01, 2008
Not Rated (0)
bignanavtf
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had the same problem.
I open it up.
On the right hand side there is a small gray box with wires connected to it. i think it the pump. i opened it up and used a trukey base thingama jig and flushed it out about 4 times. i also opened up the spray arm and flushed it also. After I pluged everything up water etc and kept on moving the arm in the gray box. The dishwasher is working now.
I hope I helped
Bignana
Thank You!
Solution #3
posted on Mar 03, 2008
Not Rated (0)
opalwiccan
Rating: 85%, 1 votes
try taking spray arm off and use turkey baster to give it a enema in the out take hole and the intake hole as well it flushed our baby good lol
Thank You!
Solution #4
posted on Feb 09, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
The spray arm is controlled by the force of the water. There is no motor running the spray arm. If water is not getting to the spray arm, then it won't spin. It may be plugged with detergent etc. Just a note re. detergent. You shouldn't use hard or caked detergents.
Thank You!
Can you Help with these Dishwashers problems?
Danby 22 in. DDW396 Free-standing...
During the prewash it doesn't seem so bas, but during...
I was washing a load of dishes this morning and the...
model # DMW946SS I broke the glass plate that spins around...
After having it for three yeras, last night my DDW396W had...
This question is for a friend of mind that is having an...
Loading problems.
Repair Service
Find Dishwasher Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
