Anti-theft system is engaging. If this is the problem try this: Place key in ignition , make sure all doors are closed, unlock the locks (via lock switch) from driver side. If this doesnt work, try the same method with ignition @ ON. Hopefully this helps
IT SOUNDS LIKE THE CAR IS IN THEFT MODE, IN OTHER WORDS THE ALARM IS GOING OFF AND THE SIREN UNDER THE HOOD IS DISCONNECTED. YOU MAY NEED TO CONSULT A DEALER FOR THE PROPER SEQUENCE FOR DISARMING PROCEDURES. I HOPE THIS HAS HELPED YOU. THANKS FOR USING FIX-YA. BEST OF LUCK. IF YOU NEED MORE HELP, PLEASE ASK.
Your battery may be dead or your distributor should be changed out. It should be near the alternator.
