Question about Radio Shack Pro-97 Handheld Scanner
Will scan manually and weather, not scanning regularly though...please help!
The scanner will not scan automatically if you press scan; however it WILL scan manually through whichever channel and whichever bank you want. It will also scan the NOAA weather channels with ease. This problem occurs very often, but, without me doing anything different, it will operate correctly on occasion. I have no idea what to do. I've gone to several Radioshacks, called the help line, checked in forums for this scanner online and still have no idea. I am out of options, so I hope that someone reading this can help! (Before I had a similar problem when the button reading ATT was engaged. I have checked this and it is not the problem now.) Thanks in advance.
    Problem Solver:
  • 8 Answers
The emergency channels have changed to digital this could be the problem cheers mick
Posted on Jan 02, 2008
Weather chanel comes in costanty
Cannot have a regularly scanned channel be a weather channel. press 'manual' on the WX channel, then press the 'L/O' "lockout" button and it will keep the WX channel out of the scan.
Feb 26, 2014 | Radio Shack Pro-2018 Scanner
Grecom psr-200 .when scanning weather chanel comes in .what is problim.
IF you have a weather frequency programmed in as a scanning channel, it will stop on it everytime, so you need to go to 'manual' on the weather channel, and press 'lock-out' so that it isn't on during scanning. You can still manually go to that channel, but it won't stop while scanning that way. Good luck.
Nov 17, 2012 | Grecom PSR-200 Desktop receiver, analog
My uniden bearcat 50 channel 800mhz stop the police,fire ect.. and only gives me weather.. why? can you help ?
  • You can try pressing "Manual" and then "Scan" or "Band" buttons from the weather setting to get you back to scanning the police, fire,etc.
  • Make sure you don't have a WX (Weather) frequency programmed into on of the regular 50 channels or the scanner will continue to stop every time around as it will pick up the WX frequency.
  • Make sure you have your scanner programmed as well.
Regards, Tony
May 27, 2011 | Uniden BC80XLT Handheld Scanner
I have the BC370CRS SCANNER I am trying to clear all the memory and reset it. It is telling me to hold down 2, 9, and hold and turn it on. That is not working. Can you please tell me another way to do...
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again. Restoring All Locked Out Channels You can restore all locked-out channels in a bank only when the bank is selected for scan. Follow these steps to restore all locked-out channels in a bank. 1. If you de-selected the bank, press SCAN then press the bank's letter. 2. Press MANUAL. 3. Hold down L/O for about 2 seconds. The scanner beeps twice and unlocks all To delete a stored frequency, press 0 then press E. Channels with no frequencies are automatically locked out hope this helps
Mar 29, 2011 | Uniden BC370CRS Base Scanner
Will not scan. Screen shows banks and scan up message.
Try this,press manual,turn squelch to silent,press scan. hope this helps..
Mar 20, 2010 | Radio Shack Pro-95 Handheld Scanner
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
For a a comprehensive database of active frequencies in your area, visit:
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Feb 21, 2010 | Radio Communications
If the weather band is working, the scanner should be working. To verify operation:
- Move the MODE switch to "Scanner" and power the unit ON.
- Press the SVC button (chrome button below display).
- Press POL (chrome button below display).
- Turn the SQUELCH knob towards the left until scanning stops and you hear a hissing noise.
- Turn the SQUELCH knob towards the right slowly until scanning resumes.
If the scanner stops on anything - even noise, it's working.
To Program:
- Slide the MODE key to "Scanner."
- Power the unit ON
- Turn the SQUELCH knob to the left until you hear a hissing noise, then turn it the right - slowly - until scanning resumes.
- Press HOLD.
- Press E (PGM).
- Press 0, 1.
- Press HOLD.
- Enter your first frequency, including the decimal point (EX: 156.055).
- Press the E (PGM) key.
- Press the UP arrow (above the SCAN key). Scanner will move to channel 02.
- Enter your second frequency, including the decimal point.
You should now have two frequencies programmed. Press the SCAN key . . .
If it still will not accept programming, let me know.
Nov 07, 2009 | Uniden BC340CRS Base Scanner
I want to my m2004 to enter barcode scan after each scan automati
Print Adobe pages 128 and 129 of 302 of the M2000 Series Product Reference Guide and scan the "Scan Options" "Data Suffix" and "Enter" barcodes. The scanner will give two beeps after the first barcode, two beeps after the second and a warble after the third programming (Enter) barcode.
The manual can be downloaded from this link:
Jul 12, 2009 | Symbol M2004 Barcode Scanner
The frequencies on my scanner are not coming in
while the weather channel is coming in hi LO (lockout) so that if its programmed into a regular scanning memory it will skip. If that dont work look for a lock button or keyboard lock and press that then scan.
Mar 07, 2009 | Radio Shack Pro-95 Handheld Scanner
Have you tried uninstalling and reinstalling the printer/scanner drivers?
May 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Radio Shack Pro-97 Handheld Scanner Logo
98 people viewed this question
Top Radio Shack Radio Communications Experts
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
