Averatec 2300 when i attempt to print the colors dont came out leki they should tried 3 differnt printers and in all the same thing happens any that can help me thanx
    Scholar:
  • 84 Answers
Delete all your printers in your computers printer applet then reattach printer you wish to use and see if after loading the latest drivers and software for it you still have the same problem
Posted on Feb 11, 2008
SOURCE:
Xerox 7328 not printing in color
Ensure that you are intalling the correct print driver, www.xerox.com, support section.
Also check to make sure that the colour option in the printing preference is not set to Black and white or grayscale.
Also ensure that you dont have any accounting option set to black and white only.
Dec 28, 2012 | Xerox WorkCentre 7328 Multifunction laser...
Printer not printing Magenta with new printer cartridge installed
Are they HP cartridges or knock offs ? Cartridges have circuits in them and they will not work if they don;t match up with the printer. If it continues..contact HP. HP has gotten real messed up in their attempt at preventing people from using knock off cartridge. So much that sometime they screw up their own HP cartridge products.
Dec 12, 2017 | HP Photosmart Pro B8350 InkJet Printer
I have a mf8050 color laser printer. I have had nothing but problems with this thing. I have had someone come to the house and work on it 2 times. When one problem solved another pops up. On that problem...
Usually laser printers rarely give such problems as you have described because they dont use cartridges like deskjet printers. The previous problem of connection has to do with proper networking and unless it is examined in person precise and concise tips cannot be given.
To print the document from the computer try changing the color of the text on the PC to a different color preferably a bright one and attempt to print. Usually this should work. If it prints this means that the toner is getting bad and needs replacement as some of the inks which aid the printer to mix the exact color is not available.
Hope this solution has been helpful?
Apr 10, 2011 | Canon Office Equipment & Supplies
At first I could not copy a document. When I
You have a non functioning printhed, but dont throw it away. Remove the print head, holding the sides of the print head. Run it under warm water for about 3 to 5 minutes until the water dropping out the bottom is clear. Run the water slow, and keep it away from those silvery things. Do attempt to wipe it dry with anything. Remember to put that grey lever down when you put the print head back. Give this a try before pitching it.
Mar 14, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
PRINTING FROM WRONG TRAY
Go to your Control Panel - Printers - [Select the LJ 2300 printer] - Properties setting on the PC and reset the default print tray to number 2
Sep 22, 2009 | HP LaserJet 2300 Printer
My hp laserjet 2300 keeps printing an error message. It began after I installed another all in one printer. the message is pcl xl error subsystem: kernael error: illegal operator...
Try updating the printers firmware.
You can download firmware here http://bit.ly/13kZ7i
If the problem remains, try replacing the driver with a PostScript-driver. That should help you out.
Jul 29, 2009 | HP LaserJet 2300 Printer
Computer does not turn on when I press the power button
do u have the power adapter plugged in, or are you using battery power? the first thing i would try is disconnecting the battery. just compleatly remove it and set it aside. then try starting it with the adapter plugged in. sometimes the batteries go bad and are corrupt. i had this happen to a compaq laptop a few years back. after i got rid of the battery it worked fine. if it works u can always buy a new battery.
Feb 26, 2009 | Averatec 2371 AMD Turion Notebook
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Open Questions:
Computers & Internet Logo
83 people viewed this question
Ekse
Alun Cox
