We have a Canon MX860 Wireless Printer, Scanner, Copier and Fax in our office. It worked for about a year, and was so simple to setup
Dial 1-800-243-0019 Canon Printer 24/7 find here Canon Printer Customer Service number 24 hour and booming path to get instant technical support for technical problems.
Call Canon Printer Support Number 1-800-243-0019 for Canon Inkjet, Pixma and Laser Printer Drivers. Contact Canon Business Support Number for your Business Printer.
the print head is blocked?
Cancel printing and turn the machine off. Then remove the jammed paper or object that blocks printhead.
NOTE
If you have not removed the protection, follow the procedures below.
1.Open the output paper tray.
2.Lift Scanning Unit (cover) until it stops.
The support of the scan unit is automatically locked.
3.Remove the orange protective tape (A) and the protective packaging (B).
4.Ensuite,
slightly lift the scanner unit (cover), fold the support of the scanner
unit and then gently close the Scanning Unit (Cover).
CAUTION
* Do not touch the components inside the machine. The machine may not print correctly.
the serial number on the this model is located on a small white label, on the front rail just below the area where you install the ink tanks. Its says `serial number' on it.
Lift the cover of the scanner. Look through the glass surface and there in tiny white print you'll find the serial number in the middle, along with the words MADE IN JAPAN. You'll really have to stick your head in there because the scanner cover is not removable and the serial number is not easily read. Make sure you have plenty of light to see in there too. Good luck!
