Question about U-Line CO2075F-B Echelon Refrigerator Ice Maker Combination
U-line CO 2075 refrigerator stopped working, only 3 years old. Service man said it needs new control board. I bought it and installed and still not running. Blinking light has indicated "open thermistor" before I changed the board, so now I am changing the thermistors. I pulled 2 thermistors out of back, but can't get the 3rd one loose. I don't want to pull too hard and rip the wires. Any suggestions? Will this likely solve my problem? Thanks!
  • SteveTX Aug 26, 2009
    It worked. You are correct, I have a 2175 (I was looking at a blog for a 2075, so I added my question).
    I was able to pull out the stubborn thermistor, replaced all 3 along with the control board. Everything is now just humming along as it should.
    Thanks!
  • 286 Answers
OK I'm guessing you have a clear icemaker. Not a co2075. When you replace the board you MUST replace the thermistors that come with the board. The board and thermistors are calibrated together. What is your model number? A clear ice maker has thermistors inside tubes. Except for the one on your filter dryer. Lets start with the correct model.
Posted on Aug 21, 2009
My LG fridge has stopped working the lights are out and its not making any noise the fan has even stopped is this fixable? As its only 3 years old
Have you tried checking to see if anything else works in that outlet? It sounds as if you have lost power to the outlet.
May 15, 2015 | LG Refrigerators
Have an Amana NAH6800, I must unplug it and plug back in to get it to start wash cycle. Also, keybord is locked until a couple of minutes after the wash cycle starts. Called repairman, he said control...
WELL IT IS POSSIBLE THE SECOND CONTROL BOARD WAS BAD ALSO? A 6 YEAR OLD WASHER IS YOUNG U CAN GET A GOOD 10-15 YEARS OUT OF A WELL KEPT WASHER.
Dec 03, 2014 | Amana Washing Machines
GE Monogram built refrigerator defrost problem
What to do? It has been in service more or less for 12 years, way past time to replace.
Mar 03, 2017 | Refrigerators
Freezer and refrigerator to cold...everything is freezing on fridge side
check for a faulty thermostat that tells the board when to run or not . If it is still under warranty have a service inspection done .
Jun 13, 2013 | Whirlpool Refrigerators
Hi ! my 3 years old fridge Samsung Rs2630ww
lashing light stating that its too warm .. compressor probably is not running / power is ok or lights would not be on . look for a bad relay . somethes you can here clicking in back.
Mar 24, 2011 | Samsung RS2630WW Side by Side Refrigerator
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Maytag MZD2766GEW side-by-side - one side is not cold
WE JUST HAD THAT SAME PROBLEM AND IT WAS THE DEFROST BOARD. $50.00 REPAIR...
Jun 15, 2008 | Maytag MSD2436GR Side by Side Refrigerator
No Cols - Temperature Controls do not respond - LED display shows a dash "-"
pencj,
My honest answer is that I have seen this before and in most cases the board works properly after the reboot.
Although you may not have lost power, you may have gotten a voltage spike. I would cancel the service man coming out, (I am a working service man myself) he probably will give you two options. #1 Wait to see if this happens again and if it does happen again soon, the board should be replaced. #2 replace the board now.
My suggestion is to soon go purchase a surge suppressor to plug into. This does not need to be a power strip style. A good quality suppressor that only has one or 2 plug in's or plugs directly into the wall receptacle should do fine. Your refrigerators maximum amp draw is listed on the model # sticker inside the refrigerator compartment.
I hope this helps, supertechks
Jan 26, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Refrigerators Logo
783 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Marvin
Marvin
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
