Question about Samsung WF337AA Front Load Washer
Samsung 306BHW-Error code 7E
Model 306BHW, Start wash cycle get code symbol 7E Silver care control problem, hardly ever use silver care, less than 1 year old,any ideas?
[email protected]
  • 1 more comment
  • Anonymous May 30, 2008
    I have the same proplem my washer is showing E7 and stops there. Can anyone knows the problem?
  • Sergey
    Sergey Oct 24, 2013
    Change PCB board (a small electric board at the back wall). Just got one today for my Samsung. Part number MES-AG3MOD-S2 however you can look at your it might be different.
  • Anonymous Mar 19, 2014
    how to replace the silver care plates
I don't know what the problem is bUT I HAVE THE SAME PROBLEM TOO ON a machine 8 months old
Posted on May 02, 2008
  • johnsen145 Jun 01, 2011
    I had the same problem and called Samsung. They also told me that I had to replace the $80 part for the siver care. I then decided to remove the top and found out that when I removed the hoses to check the screen and reinstalled the hoses, I was turning the complete valve system inside the machine thereby pulling out three of the wire connectors to the valve and the silver care part. This gave me the 7E error. I repositioned the valve and reconnected the wires and it all works fine now. I recommend to anyone that when connecting hoses that you open up the top and restrain the valve system from rotating to prevent this from happening.
SOURCE:
Samsung washer code 7e
AG+ Kit Error
Service Required
Feb 06, 2018 | Washing Machines
SUDsamsung washer error codes
• dc--Unbalanced load preventing washer from spinning
• dL--Door is in locked when washer is running
• dS(d5)--Door is open when washer is open
• FL--Washer failed to lock the door
• Hr--Water temperature control problem(Heat control problem)
• LE--Washer tried to fill but has not reached proper water level(Slow fill)
• LO--Door will not unlock
• E3--Motor not running properly
• nd--Washer is not draining/Washer senses a brief restriction while draining
• nF--Washer tried to fill but was unsuccessful
• Sr(5r)--Problem with control
• PF--Power failure, electric service was lost while washer running
• OE--Fault detected in water level sensor
• E2--Jammed key
• bE--Motor speed sensor problem
• tE--Temperature sensor problem
• 3E--High current detected
• 2E--High/low voltage detected
• 8E--Vibration sensor problem
• 7E--Silver Care control problem
• SUdS--Too much suds detected during wash cycle, unit on hold until suds reduced
Nov 12, 2013 | Washing Machines
Silver care button is jammed
Call the warranty company. If you try and repair it yourself, Samsung may void your warrantee. The silver care hasn't run out, and the service company will usually have to replace the interface or the button. Good Luck, Appliance Specialists
Jan 04, 2010 | Samsung WF328AA Front Load Washer
Can you use the silver care with a septic system?
I asked this question to Samsung support and got the following reply:
Thank you for your interest in Samsung products! Your inquiry is very important to us and I will be more than
happy to answer your question.
Silver Care is permitted for non commercial residential use only, due to the bacteria in the septic system. It is
safe to use in septic systems for residential use only.
For more information on Samsung products, visit our website at www.samsung.com or call 1-800-SAMSUNG
(1-800-7267864) for further assistance.
Thank you for contacting Samsung Email Support
Jul 07, 2009 | Samsung WF328AA Front Load Washer
Ge top load washer
Model number is on the top of the control panel on a white or silver sticker. It sounds like you have a bad timer, probably about $100 for the timer, maybe a little less.
Jan 07, 2009 | Washing Machines
Washing machine samsung
Check for broken wires.
Aug 31, 2008 | Washing Machines
Samsung WF337AA Front Loader
Hi Ya, I had exactly the same problem with my washer. 7E means that the water supply has stopped or is too weak. So I unscrewed the water hoses at the rear of the machine (turn water taps off first) and removed the little filters from the inlets on the machine by **** them out with a small screwdriver.. I then cleaned the filters out with a small brush and hot water, refitted them and HEY Presto!! All fixed. Good Luck Greg NZ
Jun 06, 2008 | Samsung WF337AA Front Load Washer
Samsung washing machine reset code
i have samsung
6 kg WA80HAG silver nano
dear'
plz help me to reset washing
machine
thanks
Mar 18, 2008 | Samsung WF337AA Front Load Washer
Error code 7E
Silver Care Kit (Silver Care PCB) Failure.
Check Silver Care PCB ,Main PCB & Wire harness
Jan 27, 2008 | Samsung WF337AA Front Load Washer
Samsung WF337AA Front Load Washer Logo
1,719 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
