Question about Canon ZR500 Mini DV Digital Camcorder
Canon ZR500 no Charge light
I have a ZR500 with no power / no charge light. Checked adapter 8.4 volts, checked battery voltage, I have removed all power from unit battery/AC without luck. Is there a reset procedure for unit ie:firmware?
Thanks,
  • 4 more comments
  • Anonymous Jan 01, 2008
    I have a zr500 with the same problem...power light does not come on when trying to recharge...have tried three different power chords. Please advse.
  • trickyricky Feb 09, 2008
    I have the same problem. The charge light just stopped coming on about the third time I used the unit. Have yet to figure out a solution.
  • steve2670 Jul 24, 2008
    I can't recharge my batteries. Can't power on, whether using a battery or cord. When I open the back, the tape won't discharge. What happened and how to fix?
  • lkjf Aug 17, 2008
    I have the same problem. Has anyone figured out a solution?
  • runner_dude9 Oct 10, 2008
    is there a place where i could take it in to get the problem fixed
  • Anonymous Dec 12, 2008
    Same here! No wonder Sony is having problems....Make junk we buy something else! I will try the fuse fix and let you know!
  • 3 Answers
From what ive been told, you might have a blown fuse. Unfortunately it is just any regular fuse its a micro fuse. It is at the edge of the motherboard with the etching H or K there are 4 of them. You can test to see if there is conductivity, if not than it could be the fuse, you can replace it or try to solder over the fuse...that would be dangerous but your camcorder will work until excess current fries it. IF not it could be a loose circuit.
Posted on Apr 02, 2008
Respected i have d610 the charging light blink 3 time red then green and not changing the battery
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 12, 2010 | Dell Latitude D610 Notebook
My acer laptop computer will not turn on, charge or anything. the charging cord has a flashing green light but no charge light on the computer.
Oct 11, 2010 | Acer Computers & Internet
My asus 100p netbook is not charging. its only 2 months old and now when i plugged the adapter its is lighting but the battery indicator is not lighting. i am running low in battery now.
First of all, you need to make sure your power adapter is providing enough power to both run the netbook & charge the battery. A very good way to do this is to compare your netbook voltage & ampere requirements (written on a sticker on the bottom of the netbook ) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the netbook's voltage rating. Amperage of the power adapter should be at least equal to or greater than the netbook's rating. It should never be less than the netbook's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the netbook, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the netbook & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another netbook, or try a good or new battery in your netbook.
If this did not work, there might be a possibility that the charging circuitry on the netbook's motherboard is defective & needs servicing. In order to do this, the netbook needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the netbook's motherboard altogether.
Oct 09, 2010 | Computers & Internet
I have a dell inspirion 1545 the power light is flashing white and orange and the battery wont charge
Oct 07, 2010 | Dell Computers & Internet
I replaced the battry in my laptop and now the charge light does not go off even when it says its full it keeps trying to charge.what is wrong?
Sep 29, 2010 | Computers & Internet
Battery light flashes red. Battery will discharge but not charge. I have a cf-50 which is having the same problem. I replaced the battery twice but the batteries will not charge. I tried refresh. I...
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Sep 14, 2010 | Panasonic Toughbook 50 Notebook
When i plug the charger in the light on the charger pulses on and off and i don't get a charge
Sep 08, 2010 | Computers & Internet
Battery of my laptop is not charging .It is constantly showing 37% charged. charging is not increasing nor thegreen light is glowing but laptop is running with A.C. power. AC power light is glowing...
Sep 08, 2010 | HP Pavilion dv6000z Notebook
Hi' I have a G320 laptop, which will not charge the battery. It does not register charge on the indicator light, or through a check on power options. I purchased a new battery, believing that my battery...
Sep 05, 2010 | EliteGroup G320 Notebook
No power
first it is not the volt but the current the barrery is having. check it with milliampere meter, because even a recently dead battery may show you proper voltages. second yes there are safety fuses in the power section near the battery terminals and power socket. try locating and check for continuty.
Oct 09, 2006 | Canon PowerShot G2 Digital Camera
Canon ZR500 Mini DV Digital Camcorder Logo
546 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
