FixYa.com
Tags:
Compaq Inkjet IJ650 Printer
Compaq IJ650
By pawa - usenet poster
I have a new printer of the type above, and I can't seem to change the
preferences to reflect NOT reverse order.  It keeps going back to reverse
order, unless I change the "preferences" once the print job has been ordered
up by the computer.  In the  screen where you tell it which printer to use
and it asks preferences, it will bring iup the screen where I can deselect
"Reverse Order" and then it will print in the correct order.  If I ask for
page 1, it will print page 1, even when set for reverse order.
What could be the problem?
BTW, none of my messages are showing up here from today, does anyone else
see them?
c.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thx Jonathan, Me, along with Compaq tech sup. tried to that over and over
again.  It just wouldn't work.  We did uninstall the Monitor software that
seemed to interfere with it. Also my printer driver software CD said it was
bad and then wouldn't read upat all, so in order to reinstall it I had to
download a driver.  Well, last night the printer decided to fix itself, now
it prints in normal order.  I did some updates with Norton, so maybe that
fixed it, I don't know.
Thx for the info.  In each app I'll check prefs as I go to make sure they
are set the way I want too.
I appreciate the dialog.  Blessings!
c.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Perkins
Perkins - usenet poster
Rating: 0%, 0 votes
Setting the preferences in the application will not set the default setting,
you haveto do that within the drivers preferances dialogue. Do this by going
to Start / settings / printers and select the icon for the printer in use.
Right click on the icon and when the dialogue appears select preferances and
make your changes in there.
Within word you have to set revers order in word's own options menue system.
Cheers
Jonathan,
printerso @eircom.net
Have a look at my Local Model Aero Club site
The Enniscorthy & Co Wexford MAC
http://geocities.com/e_and_cw_ mac
Cheers Jonathan Hon. Tres.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.368 / Virus Database: 204 - Release Date: 30/05/02
Solution #3
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
I tried that, and it isn't even set up there.  Plus, it doesn't have
"reference order" selected.  According to Compaq, unless I want to try
reloading the driver, or if that doesn't work reload Windows XP, I'll just
have to live with it.
As I said, I installed some software for the monitor, which was after the
fact of using it for a week, but I just found the disk and read in the book
to install it.  My monitor is a Compaq LCD and it was a "Plug and Play" and
I shouldn't have needed the software.  Well, the softward caused my printer
program to be corrupted and actually ruined the CD somehow or made it so
that Windows won't read it up.  Now, with help of Tech Support I have
downloaded a new printer driver, but I'm chicken to install it for fear of
more stuff happening.  The Monitor softward I put on has been uninstalled,
so I'll dry again later.  Compaq acknowledged that they have been seeing
this same problem and it is bug.
c.
Solution #4
Not Rated (0)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
Also, I have tried to reinstall the software, but my CD Rom drive won't even
read it up.  While installing the software I found out I was supposed to
install for my new monitor, a window popped up saying the computer had
recognized new hardward, namely this printer, which I had installed with
it's drive 3 days ago and has been working.  Now the CD Rom won't even read
up so I can try reinstalling it.  I'm afraid to uninstall it bc if the CD
rom is no good, I'll have no printer driver.  AT least the printer is making
good printouts.  Just in reverse order.
c.
Solution #5
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rating: 0%, 0 votes
I know the problem, the configuration in the "printer" in the control panel,
is the "default settings" these settings will be used everytimes you don't
change the config after, so just deselect reverse order in printer in the
control panel (properties on the printer) then try it... It will probably
work!
Mat128
Solution #6
Not Rated (0)
Melissa
Rating: 0%, 0 votes
BTW, the status monitor says it is printing page 3 when it is printing page
1 and so on (if there are 3 pges to print)
c.
Can you Help with these Printers problems?
ij650 printer doesn't print.
I have windows xp, and the... Answer This...
incomplete fonts
I have compaq presario and a... Answer This...
no power
how to solve this problem Answer This...
Cleaning rollers
I have a donated printer I just... Answer This...
Printer won't print anymore...
My printer use to print, but... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
